- Staff
- #21
The location of the fuel pump causes it to rust out the mounting flange. I had to have it replaced a few months ago. I have since parted company with it at the time I bought the 2013 Duramax
It is in tank. But that is a problem even if rust free because there's a recess where the pump unit is mounted and water sits there.I rhink this one is in tank with FPR as one unit haven't double checked
Truck is 99% rust free thankfully
Something going on internally to #4Moved coil, plug wire, plug, and injector. Code stayed on 4..
I didn't get to work on this weekend and all "missing" parts accounted for, However you are right I do need to do the compression test at the stage. Idle seems to be the the wild card, going down the road it runs good and is not throwing any codes till you get in to stop and go traffic.One of the few things I learned in an automotive class by an old GM mechanic who was teaching it: Debris in the intake doesn't follow airflow. The valves and pistons are moving very fast. This speed can smack the debris and bounce it out of the head port (even clean out of the cylinder) into the intake or another head intake port. Vibration and airflow can move it into another intake port from the intake.
This is especially weird with debris in the exhaust getting into the engine. Best example is a manifold cat failure (Nissan V6) getting debris back into the cylinder, scoring it up bad enough to lock the piston up, popping a rod, and hot oil hitting that failing cat burns the car to the ground.
In diesel engines turbo failure on the exhaust wheel only can get into the engine... Don't get us started on glow plug failures becoming debris...
The picture above with the worm clamp screw: the clamp itself was in another intake port.
The above said the minimum needed is to do a compression check on the other head that wasn't removed. Maybe you got lucky: Vegas Odds say you didn't.
