2004 Yukon XL 2500 LBZ
Sorry it's been a while. First baby was born back in July so life's been a bit busy since then. Made our trip out to TN and back (not without issue). I've been having a problem with the high pressure power steering line coming lose at the back of the pump and destroying the o ring, then pumping out all the fluid in about 10 seconds worth of time. This has happened 3 times now (most recently in TN -- thankfully we made it out there fine). I didn't have access to a shop/garage, so I paid a shop to replace both high pressure lines and the return line as well as a new PSC pump. All seems to have been fine since then.
Not sure if the cat filter was causing the noise issue with the fass pump, but currently have both fass water separator and fuel filters and sounds smooth again. I'll stick with their filters for now and keep an eye on it.
This last weekend I did some maintenance and still tracking down a steering issue where its still got a weird almost flat spot feel in the steering that was most noticeable in turns and perfectly straight highways. kinda felt like it was constantly needing correction left and right. keep in mind Im super sensitive to imperfections like this. so it was bothering me -- most other people probably wouldn't think twice about it. I was assuming either a damaged pitman/idler or tie rod end from when I was hanging on the wheel to get it turned into the driveway the second time it puked all the fluid out. or I did some internal damage to the pic box. either way I made the decision to change all the steering joints.
I drained and refilled Front and Rear differentials, Transfer Case, Engine oil and filter, Transmission fluid and external spin on filter.
For the steering, I replaced the PSC steering box with another, same Bigbore XD box, Kryptonite death grip Pitman, idler and idler pivot assemblies. New PPE OE style center link and new Kryptonite Tie Rod ends. I got the steering close to what it was still doesn't feel perfect, but I've got an appointment to get it aligned this Thursday so hopefully that will clear that up.
Also need to drain and refill coolant as it's been about 5 years.
Old box out:
New box in:
New Pitman Arm installed:
new idler/pivot installed:
new ppe center link installed:
to be continued....
new steering stabilizer installed:
new tie rod ends:
Using my buddies shop has been a dream. it's a 300 mile round trip from my house but ohh so worth it.
Old steering linkage assembly:
new parts:
Even snuck in a trip to the beach for some fresh clams:
And bbq'd them on the beach. can't get much fresher than that.
Thats all for now. I'll update after alignment and coolant change.
Then we've got some trips lined up (hence why time to do maintenance now):
Oregon in a couple weeks, then a snow wheeling trip towing the jeep up to the sierras.
Then gotta make it out to NM to visit sister in-law that recently had a baby.
And finally to Idaho to visit some friends the just moved out there.
That gets us to this summer. Then we'll see what happens from there.
Got the alignment done. Steering feels like new now.
Got coolant drained and refilled, took about 3.5 gallons.
Windows all cleaned up and treated with Aquapel.
Changed a rear door latch that was acting up.
Checked trans and power steering fluid levels.
Aligned headlights and fog lights.
Started loading up for our first trip this year up to Oregon. Might be hitting some snow as he head over the pass.
I’ll double check coolant level and then we should be ready to hit the road.
so got the truck all good to go earlier this year, we got a trip to OR in but then diesel fuel shot up to over $8/gal here in kommifornia. I made the hard decision to park the dzlburb for a bit and started driving the 2013 Yukon XL K1500. Took that to NM, OR and a few trips up to the family cabin. I added an AFE trans cooler and that truck has been pretty good and doing a great job. Meanwhile the cost of diesel has come back down a bit (~$6.50/gal around here) but now the A/C has been acting up in my dzlburb and I won't have time to sort out the A/C before we leave. so this next big trip out to CO, TX, AZ and back home will be in the 2013 K1500. hopefully after that I'll have some time to tear the dash out and pull out the HVAC box and redo all the AC stuff in the dzlburb then we should be back in business for our next trips. I really miss driving it.
Doesn’t the diesel get far better mileage than the gasser?
I'd like to say yes. But reality is unloaded the diesel avgs 19mpg and the 5.3 gas aves 17mpg all hwy. In town both avg 14-15mpg. so unless im towing or hauling heavy loads its hard to justify the diesel when its more then $1 more per gallon. and the 5.3 on e85 avgs 14mpg hwy but its $2.99/gal -- so I use that when it makes sense otherwise RUG is saving me a little bit right now. might seem like im pinching pennies and maybe I am a bit but saving up as we need to move soon so any little bit helps.
We moved to Montana. Diesel was still $3.77 yesterday, but other stations jumped from $3.83 to $3.99. Some stations in Missoula as high as $4.19. RUG was $3.83.
Get out of kommifornia before it take you with it.
