Loganshaw_6
- Messages
- 61
- Reaction score
- 34
This is my first post on here hopefully it's not a tough one for you guys to help me figure out.
I bought a 1998 Chevrolet c 2500 with a 6.5 in it not running. I was told it would start when cold but not when hot. I ended up replacing the injection pump with an ACDelco remanufactured pump. New PMD (relocated behind the grill with a heatsink) lift pump, ECT sensors, IAT sensor, used good ECM, glow plugs, starter, and batteries. everything has been replaced with ACDelco parts with the exception of the IAT sensor, starter, and batteries. Previously I installed 2 remanufactured pumps from Diesellogic.com first pump leaked, second pump was diagnosed by SMR Diesel in Colfax, NC to have a faulty optical sensor as the truck was losing cam signal past 170 degrees. I now have the AC Delco pump in the truck and it will run past 170 degrees but RPM will fluctuate from 700 to 680 and begin to run poorly. The truck will run past 170 but will eventually cut off on its own or if you try to give it any throttle. If you keep the RPM above 1000 the truck will run but if you let off it will die. I'm using a Snap-On Solus scanner to set timing. TDC offset is at -0.46 with time set enabled my desired timing is at 0 and my actual timing fluctuates from 3.5 to 3 3.8. I have been reading forums trying to understand how the truck works and make sure I set timing properly. I believe I am doing it correctly but please let me know if there's something I am doing wrong as this is my first 6.5. My truck has a factory EGR my new used computer came off of a truck without an EGR. I relearned to the computer and got a security light to go away. The truck still has the same problem as before. The truck runs great it starts right up cold but once it reaches 170 degrees it starts to run bad and cut off. I have not personally checked the timing chain yet but I have spoken to multiple shops and they believe since it is not throwing any codes that the timing chain probably isn't the culprit. I only paid $650 for the truck with 190,000 miles so I'm trying to stay relatively cheap. I am a lead tech at a GSE shop at PTI Airport in Greensboro so I am capable of working on all types of things gas, Diesel, and electric. At this point I'm stuck with what to do. Any help is greatly appreciated! I figured I'd post on here before I take it to pure diesel in kernersville, North Carolina and pay them to diagnose and fix it. I'm new to this forum and I have never been very good with posting on them so I'm not sure if my signature will show up.
