6.5L 1995 Suburban with Optimizer & DB2
bobbiemartin
Author of The DB2 Conversion Guide
Jacksonville, Florida
We are the original owners of this Suburban. The engine has been replaced with a 6500 Optimizer AMG engine with a DB2 injection pump. Details here
It developed a problem, details here
The body is in great shape, no rust or crash damage ever. Rare teal blue, rear tailgate, factory towing package. Is a 2 wheel drive 1500 so has a 3.42 final drive. GM reman 4L80E with standalone transmission computer. 2 good Optimal batteries. Custom made extra size battery cables. Lots of other upgrades. Delco in dash CD player with 12 disc changer. Has factory alloy 8 lug wheels with Load Range E tires. LS trim, drivers seat needs upholstery, passenger seat is fair. The balance of the interior is good. Recent AC compressor, wheel bearings, tie rod ends, etc. Always use the best parts I can find. Have receipts going back years.
Engine currently out and partially disassembled. I'm in Jacksonville, Florida. Clear Florida title in hand. $5,000 takes it all. Would like to sell as one lot, but may part out if no interest.
Lots of pictures here:
Thanks, Bobbie Martin
I'm ready to part out the mechanical stuff. I'll get a full list soon but almost everything is available.
Rolling body complete with interior, alloy wheels, etc. $1500
GEP short block with ARP head studs $2500
Includes flex plate, oil pan & turbo oil pump
GEP Turbo Heads $750 for the pair
GM8 turbo with Turbo Master $250
8X Bosch injectors, never installed after being checked and proclaimed “perfect” by injection shop, with install kit (less 1 crush washer) $400.00
LH exhaust manifold $75
RH (turbo) exhaust manifold $125 (I have 2)
Intake (no egr) $60
Intake top $25
K47 airbox with K&N $75
3” mandrel bend exhaust $125
2.25” mandrel crossover $40
Mandrel bent downpipe $60
HO water pump, spin on type $25
Hayden “Truck Fan” clutch $60
21” 9 blade Duramax fan $60
GM Trans control Computer #16196390 $125
Oil pump drive with speed sensor $50
GM reman 4L80E $500
Aluminum Suburban driveshaft $100
Mann Pro Vent 200 $100
Fuel manager (filter) $30
Racor fuel filter and custom mount $50
Starter $75
Bosch “new” alternator (not rebuilt GM) $75.00
Radiator overflow tank for K47 filter $50
Lift pump $30
If you want something that is not listed let me know.
All prices plus shipping
Package deals, let me know what you want and make an offer!
I definitely want the provent.
Db2? How many miles on it and did you do anything to it beyond stock like hardened parts inside?
And I would like the cruise cable assembly just as a back up I think, checking numbers to see its same as hummer.
If anyone out there NEEDS these at his good prices, I can pass. Just gonna sit on my shelf for some time before I get to it probably next year.
DB2 and injection lines are sold, as is the Racor filter.
Please PM me and I'll figure shipping on the cable & Pro Vent. Thanks
OK this is what I have left, plus a few new items.
RH (turbo) exhaust manifold $100
Intake manifold, no cracked ears, great shape (no egr) $50
Intake top $25
3" mandrel bent exhaust system $100
Mandrel bent downpipe $50
GM standalone Trans control Computer 16196390 $100(for DB2 conversion)
GM reman 4L80E with PML deep aluminum pan $300
Aluminum Chevy Suburban driveshaft $100
6.5L Diesel Starter $75
Lift pump $20
Delco in dash AM/FM CD player $40 (fits 1995 to ?)
Delco remote12 disc changer $40
Provent 200 $100
Also parting the body. Front fenders, bumper & front door panels sold. Rear window & Alloy wheels sold. Pretty much everything else still available.
Custom made battery cables. Complete set of battery cable, made from double 0 cable as I recall (plenty big enough) for two top mount terminal batteries. Complete positive cable from side to side and down to starter. Power wires to alternator (with fusible link) and to underhood fuse box. 2 negative cables to engine, cable from engine to chassis ground, plus another chassis ground to engine. Very well made and they do the trick $100.
Alternator bracket with mount for Provent 200, or use just for alternator $25.
Also odd brackets, glow plug relay, etc and small parts, please inquire.
Is the underhood firewall insulation any good? That may sell as it's NLA.
AC Hoses are 6.5 unique so sell them. Someone will have a need for them... The HVAC control head, working, also is a 1995 unique part that fails often.
Note I don't want them just pointing out the rare items that should be sold not scrapped. :D
The following are sold or tentatively sold:
LH door mirror
Rear Bumper
Hood latch
AC Compressor
Exhaust and downpipe
4L80E Transmission
Front Bumper
Center console (lower)
Front door panels
Alloy Wheels
Front fenders
LF door
Radio CD Changer
rear speakers
Lift pump
LH exhaust manifold $50
RH (turbo) exhaust manifold $75
Intake manifold top only great shape (no egr) $25
Cruise control cable for Electramotive cruise box to DB2 injection pump $50
Diesel instrument cluster tach/speedo, etc $50
3" mandrel bent exhaust for Suburban $100
3" mandrel 6.5 Diesel down pipe $40
Intake manifold for turbo top section only $25
1995 6.5 Diesel powertrain control module (computer) $25
Aluminum Chevy Suburban driveshaft $75
6.5L Diesel Starter includes front mounting brace and heat shield $75
4L80E transmission, GM reman with PML aluminum pan $300
Wiring harness for 4L80e, all connectors $50
1995 6.5 Diesel Suburban front/rear air AC hose for compressor Genuine GM $50
Single thermostat water crossover $40
Valve covers powder coated hammertone silver $15 each
E-1796 K&N Filter, good used $30.00
CDR valve for 6.5L Diesel $15.00
Glow plug relay $15
Bilstein shocks for 2WD pickup, Suburban or Tahoe $50 pair (have front & rear)
Receiver hitch for Suburban or Tahoe $40
New in bag GM 15613086 clip for hoses $5.00 each, have 3
Rear window (hatch style) factory tint for Suburban $100
The Suburban and engine are sold, except for a few brackets and heat shields, this is what I have left:
Glow plug relay $15
Custom made battery cables. Complete set of battery cables, made from double 0 cable $100.
Roof console with Homelink garage door opener $60
Auto dim Compass Temperature rear view mirror with temp sending unit $25
