rlb
A few months ago I picked up a 1994 K2500 Suburban 4x4. Curious what kind of MPG you all are getting.
I got 12.5 MPG on a recent highway round trip of about 250 miles. I usually set the cruise at 65MPH. Was expecting ~15MPG. (Let me know if this is unrealistic)
The truck has new tires (cooper H/T). Axles, Tcase have fresh fluid. Transmission is shifting well and overdrive is working fine.
No check engine light. Recently replaced the O2 sensor with a Bosch ($20, I figured what the heck) and spark plugs, wires, cap/rotor are new. Motor runs well although it seems to idle a touch high. The coolant temp sensor on the manifold looks newer. (Had a head gasket job before I bought it, was replaced then). Even when the truck is warm from a long drive, the exhaust smells a bit like it is running rich. Maybe I am just used to the more modern MPI systems with 2+ spark plugs that run (and smell) really clean.
If 12.5 MPG is all I can expect then I can live with that. I bought this as a 2nd vehicle and not for a cheap commuter. But I would like to make sure the truck is running as well as it can. I think my next job is checking the injectors for good flow and ensuring the ECU is getting a proper reading from the coolant temp sensor and not running it too rich.
Any thoughts? Links or advice on accomplishing the above two tasks would be appreciated. I haven't worked on OBD-1 vehicles much.
