bigjerel
So this is completely confusing me. I start it up and the thing runs perfectly...hits all gears, OD works...everything shifts just like from the factory. After about 20 minutes it just loses its mind. When I stop at a light, it wants to try and start in second gear. If you kinda goose the pedal, it will usually drop into first and start rolling as it should. Then the other day, once it started acting up, it decided to only shift into second gear...nothing else. I was able to make it home, and as soon as it cooled down and I tried it again, it worked fine for awhile and then started doing the same thing. I went ahead and dropped the pan, replaced the filter and fluid, and when I put everything back together again it wouldn't even shift into gear. I had to drain out 4 qts, then add 1 qt at a time and shif through all the gears and finally after getting the 3rd one back in I was shifting in gear again. Ran good for a couple of days and then back to the same old thing. I bought 2 new speed sensors this evening and changed both of them out, but when I pulled them, no fluid leaked out. Coach is sitting on a small decline and hopefully this is why now fluid came out. I cleaned both of the connectors and the main connector with the screw in it was covered in tranny fluid so it go a healthy dose of brake parts cleaner as well. Letting it dry overnight and will try again tomorrow. Anthing else I should be checking on this thing? Really hard to believe it is something other than electrical when it works fine for a half hour or so and then starts getting goofy. Thanks for any suggestions.
