The BEST advice ANYBODY can give you is to NOT buy online, ESPECIALLY EBAY! There is way to many on ebay selling counterfeit Chinese copy parts, there is no way I would trust one. 2nd, when building an auto, there is almost a 100% chance you will run into a problem, and need to swap something out. I've built several 4l60e's over the years, just did one last week, and ended up making 3 trips back to the trans shop. 1 for bushings that were bad right out of the box, then for a clutch pack that didn't stack up right, and finally another for an upgraded servo I forgot to order at 1st. It happens, and unless you've built quite a few and have extra selective steels and such on hand, you're bound to have to swap something out. And finally, buying your parts from a respected trans shop/supplier can pay back in dividends with knowledge if you run into a problem. There's only so much info you can get out of an ATSG or similiar manual, and thats where the knowledge of an experienced builder can be invaluable in helping you with the small details. Many times its the little details that can make the difference between a rebuild that craps out after 5k miles like the one I just built, or one that outlasts the factory unit.
