‘98 6.5 TD stalled while driving and current no start
So completely new here (just got a 96 TD in Jan) been chasing electrical issue in mine. And have discovered that transmission and engine are separately run and only "touch" in two places the PCM ground and the power from Ignition switch. Your original issue was transmission. And you have crank but no fuel at injectors. So a bad ignition switch can supply power for starter and LP but not supply power to PMD (through PCM power and ground) and Transmission. So would have fuel up to IP but no or bad signal from PMD due to low or "bad" power so wont send fuel to injectors as would have no timing info. This would also give codes you are getting on cranking. This would have you looking at the location that would effect both transmission and crank no start. You said you found bad grounding at PCM strap which could cause failure in ignition switch due to amp draw to overcome "bad" grounding. (Also did you check fuses? ECM, FUEL SOL, IGN A/B) you can look for battery voltage at PCM And PMD (This part is from AI as dont know wires and locations and to lazy to go through wiring diagrams) PCM is C1 or C2 pink or orange wire, Stable >9.6 on crank(should match battery voltage). And PMD pink wire at connector. Stable battery voltage during crank. If >0.5v off of battery voltage, bad ignition is probable. Also said not seeing codes from transmission. This could = no power to transmission module so ignition switch again.
But do try all above suggestions as I've just started to learn these trucks and could be completely off as there is something the above people know that removes ignition switch as possible cause of failure. But I think ignition switch should be considered if come up to a point where might be a LP or PDM replacement as ignition switch is like $50 .
Ok. First two codes tell us the ip (injection pump) is not happy with fuel situation inside, but when there is not proper fuel flow of good clean & air free fuel flowing through it- that can happen. So we set those aside for the moment because of the third code and more importantly your comment about what you saw in the clear is return line. Your description sounds like the LP is leaking back fuel to the tank and not supplying fuel right away.
I think you do not have adequate fuel supply to the ip or bad FSO. You said
“-tested fuel shutoff solenoid.
-tested lift pump (runs while cranking”
We need to know how this was done because some folks test by just listening for a sound on both.
The LP (Lift Pump) should be tested by a pressure gauge after the rubber hose ends at the ip inlet. It is done at this point to ensure not just the LP but the interior of rubber hoses in all locations are not having issues. MANY MANY ip have been replaced while good because the inside of the hose is deteriorated restricting flow and people replace both LP then ip then have same issue. The proper pressure is 8-14 psi. But as long as you have a couple pounds- it should be able to start and idle ok. When it goes into the negative it causes major damage to the ip & imo is the #1 cause of premature failure of ip. For this reason and speed of diagnosis my long term suggestion for owners is a metal T fitting attached to the ip inlet acter rubber hose ends. The 1/8” port on the T fitting is for a fuel pressure sensor and a permanent mounted gauge in the dash so you see it while driving.
At this point- run a jumper wire to the LP so it is on constant and read the pressure.
You are not getting fuel flowing through all the time like you should.
The FSO (Fuel Shut-off Solenoid) is in question at this point. It could be the electricity is not feeding it properly, or it is not operating properly, or fuel supply to the ip is inadequate.
Your FSO works like this: there is a plunger on the end inside the ip. Key off it sticks out and stops the fuel from leaving the ip. This restriction does not allow new fuel in and shuts off the engine. Pinching the 1/4” return line closed does the same thing. If you ever turn the key off and the engine won’t die- go pinch the 1/4” hose and the engine will cut off.
When the key is on, the plunger in the solenoid retracts allowing fuel flow through the ip and out the injector lines at roughly 4,500 psi- so never put your fingers infront of the metal injector lines.
Removing the FSO is done by unplugging the wire and unscrewing it like a bolt.
With it out & the key on, fuel will pump out that opening. If you unscrew it part way, a little can leak out, but will allow fuel flow through and start the engine-
Also by removing it- you can turn the key on and see it retract- but the LP should pump a bunch of fuel out the threaded hole when this occurs so unplugging the LP first is advisable- unless you want a messy 2 for 1 diagnosis.
You can remove the FSO place the body (not threads or plunger) on the negative battery post and add a small jumper wire from the positive post to the connector and see it activate. Those are the basic versions of testing it most folks do… but seeing it work in place is simply - turn on the key, jumper the LP and watch fuel flow through the clear 1/4” line & knowing you have proper inlet fuel pressure- tells you all that is working properly.
Anytime there is anything in question with the engine running right- step one from GM is clear line test and step 2 is fuel pressure at the ip. So I harp on gauge In dash & leaving the return line clear. Fuel-line.com sells clear line that is rated fuel line to withstand the ethanol in our diesel- it isn’t rated for things rubbing against it so just be intelligent enough when installing it to not let it rub anything. The stuff for the hardware store lasts a few years and needs replacing. Either one works.
Please describe your testing of these in more detail. You need to be 100% about these before going down the rabbit hole you are faced with next.
Thank you for this detailed message. I initially checked the LP by checking volume at the inlet line at the IP. However I am currently working on getting the permanent fuel pressure gauge installed as recommended. So I will know more at that point.
When I tested the FSO Solenoid previously I did it in all of the ways you described (minus the messy 2 for 1, I had the LP disconnected when I tried it).
I do think I may have found my issue though. I pulled the intake manifold to get a better inspection on all of my lines, wiring harness, and to give more space for installing the pressure gauge. I found that my main line from FFM to IP was very weathered, and it broke open upon removal. I didn’t have much puddled fuel like it had been leaking, but I wouldn’t be surprised if it was pulling air through it. Does that sound like a reasonable assessment?
I will send videos once I’ve got everything re-installed if it’s still not working. Is there anything else I should do or check while I have the intake off?
Be sure You get a snubber with that FP gauge.
Some lift pumps may not require a snubber but if Yours does and no snubber is in place it will take out the sending unit on an electronical gauge or could damage the gauge on a mechanical gauge.
I went through three FP sending units before what was wrote in this forum took a hold in my brain.
Should have been under pressure so it should not have pulled in air, unless, the lift pump has failed.
Absolutely bad fuel line is a super common issue.
When you buy the new fuel line:
SAE30R9
Modern diesel has ethanol/ methanol in it. Our old lines do not withstand it and deteriorate from the inside out. So from outside it can look and feel perfect.
Having this grade line is not an option but a requirement imo.
Here is the fun part… there is also rubber line at the fuel tank. Either lifting the bed or dropping the tank is required. Most drop the tank.
While the tank is off becomes another barrage of what things you can do while there.
I suggest do the lines at the engine first. Make the tank a separate project.
Now, while you are at the engine rubber lines-
Stock is 3/8” from tank to ffm. Then 5/16 from ffm to ip. It is more work and money on parts to make an improvement while there called FTB Feed The Beast (love the name Tim!) the ffm gets modified to use 3/8 fittings as does the ip.
Leroy sells premade FTB ffm for people.
Idk if Tim still sells the fitting kits or not. Doing this before buying the T fitting needs to be known so you get the right size.
A different option that is more expensive but far greater long term- throw out (ok sell for a few bucks) the ffm. Throw out the factory LP. Buy a FASS LP with filters.
It will clean fuel better, stop all the water that can kill the ip & injectors. The factory filter can only stop a tablespoon of water then it bypasses water to ip. The FASS water separation filter holds massive amounts of water and will stop flow when full.
The filters are much larger so don’t need servicing as often. You will find the stock type of LP can not supply proper fuel pressure with the new fuel we have, it barely did with real diesel. Proper range is 8-14, but will run ok with less. Under 5 it will starve a bit when under high demand, under 2 it is horribly noticeable power loss, at 0 or negative pressure it is doing major harm to the ip (and running bad). The Fass just gets pressure adjusted and is rock solid to outlast engines.
Many people use the Fass (or Airdogg but Airdogg lacks the amazing water filter) and set it up to run continuously when key is on, pumping mass amounts of fuel in a cycle back to the tank so that it polishes the fuel to incredible levels. With the FASS it’s still recommended to upsize the ip inlet fitting.
ON THE FTB or FASS
Less restriction in the system is noticeable when driving even if the stock LP is used- especially when better LP is used. More fuel flow benefits the ip.
It isn’t necessary but helps.
Good news everyone, I got it up and running. I replaced all of the soft fuel lines throughout the entire truck with new fuel lines of the rating Will recommended above (I haven't upgraded size yet but will be doing so when I upgrade LP). My lines above my tank were to the point that they were visibly collapsing upon activation of the LP. Went ahead and eliminated stock tank sock and added an inline fuel filter just in front of the tank, that way I don't have to drop the tank again when it comes time to upgrade to FASS.
I also got a fuel pressure gauge lined in. I'm getting 7, 5, 2PSI on stock LP (not-running, running, and under load respectively). Truck runs and starts perfectly though. In fact, it runs better than it's ever ran for me.
My transmission issues were either from the ground that I found initially, or if the PCM works anything like how it works on my 1994 5.7, the lack of proper fuel flow under demand could have been causing it to downshift due to improper power supply<demand.
My next upgrade is getting a spring wastegate controller, boost pressure gauge, and egt gauge. If anyone has advice on these upgrades, please let me know.
