MrMarty51
I did make up a ground and attach it to the blower cage and to the ground lug and it made no difference in the motor or fuse temps.
No.
No.
View attachment 100034The wire issue that was mentioned isn't the plug on the motor back a foot or so there should be another.
I had to do to a job at Roberts Montana, when I get back home I will check for that second plug.The wire issue that was mentioned isn't the plug on the motor back a foot or so there should be another.
If the fan is getting hot, I'd just replace it. Or rebuild it, if that's possibleIf this only happens with the fan on you need another fan, at least it's the easiest and doesn't cost a lot, that would take the fan out of question...
