Swapping out the sensor is no biggie. It will leak some coolant when you do it, so just get the old one loosened up, then have the new one close so when you pull the old one out you can quickly install the new one.
Top off coolant and bleed out the air afterwards. Good to go.
I would suggest getting a Delco sensor from an authorized dealer like Oriellys, napa, etc though instead of ebay. There are so many poor quality parts that fail much sooner out there, saving $5 isn’t worth it.
Try to get the new sensor started, before you drop it and have to crawl under the truck to get it while the coolant is draining overhead - actually this is the way I do it. I don't think it is the preferred method
Sir, the sensor is fine, its just the cable that connects to it is damaged due it being partially melted
is your cold advance and the idle up solenoid connected in series to the coolant sensor? not saying it is the problem but those idle up solenoids draw a bit of amperage and could be drawing too much (getting old and going bad) if this is the case, it can burn out the sensor in the coolant crossover too. I always like to run a relay on things like this to avoid burning out a sensor that is hard to obtain on top of drawing too much on the factory wiring.
you can splice a relay into the wire coming out of the sensor going to the cold advance and idle up solenoid and power the relay off the battery. that would isolate the load on the sensor and stop the melty things. but this would not fix it if it's drawing too much. IDK what they ohm out at when good, someone would have to put an ohm meter on their good one and then compare to yours to see if that is indeed the problem.
The relay mod will only save your sensor. that thing new is up around $80 by it's self and iirc NLA from GM. there are a few aftermarket ones available.
Im not sure sir. All ive noticed is that a wire that's supposed to connect to the sensor us damaged, thats it really.
When my GPs cycle (and the GP light goes on and off), i do notice that my voltage goes up and down drastically
GP's have nothing to do with that part of the system. that sensor only controls the cold advance and high idle solenoid that's on the IP
That is if were talking about the same sensor! post a pic of the area and the melty connector
A relay is not needed on these. The sensor life is frequently 35 years.
That picture shows the sensor took a physical hit. That tiny hole in the middle of the flat spot used to be where it was soldered to the sensor.
That sensor in the picture- buy one and install it.
There is a temporary fix until you get it installed:
Run a wire from your ignition accessory through a 5 amp fusethrew a switch, to those wires that are broken off the sensor in that picture you posted. Make sure to electrical tape up those exposed pieces of metal.
When starting the truck in the morning, turn on the switch. When the ect gets up to 160°f- turn off the switch. That is all the sensor is doing.
Leave it alone . Tape it and forget about . The new number is 23504005 . The Diesel Place has a few threads on it . Basically GM found out that they needed glows even when warm . That was a switch and then just a shunt . My 86 has it but yours being a 91 may be different .
Mines is a 85 sir, it was swapped into a 90 K5 body
Looks better. I’d still feel better if ya fixed that low coolant warning.
Overheating is #1 killer of this engine. If you leak coolant below to temp sensor- it will never read hot. Many rigs like my hummer don’t even come stock with one unfortunately. So we have to add it aftermarket.
I say get that safety net working soon
I actually found the sensor for it but when i connected it to the wire it came out off the coolant sign was still illuminated.
(Yes I turned the vehicle on and off twice to make sure)
That sensor is in your radiator? I would pull it out and see if it's not got some rust film on the probes. normally these work the same as a "water in fuel sensor" there are two probes on the end of the sensor that stick out into the coolant. they touch the coolant and make contact turning the light off if the connector is a two wire, you can test the circuit by using a jumper wire across the two terminals and see if the light goes out. if not, there might be a wiring issue going to the sensor. maybe a bad ground. I don't think I have ever seen those low coolant sensors go bad.
