Suggestions…recommendations needed drive line
panran
Colorado high plains 6300 feet
Would like some advice from experienced dually 6.5L dually owners or past owners….well I’m getting excited about finally experiencing a real truck. I haven’t tried to start my truck in about six months and to my surprise it fired right up, well in the past it took about two or three battery charges to get fuel to the IP, so I pulled the gp and loosen the injectors thinking it would be less work on the battery and bam the first crank I smelled diesel…so in the past there was always a fuel pressure leak and thanks to a lot of help on this forum problem solved. So I’m moving forward in phases starting from hb and pulley and cross over now waiting on delivery of front pulley drive components so I will have water pump alternator vp ps,ect that should be here early next week…. So what would be helpful is drive shaft components, I’ve looked on rock auto and overwhelmed at the choices…2 piece driveshaft and carrier bearing so 3 universal joints… where I am at now Colorado high plains have a mile and half of washboard dirt road before paved and a lot of up and down two lane roads, so would be a lot of abuse ( rear wheel drive) also need to make 1 or 2 trips to Illinois with 16’ enclosed trailer. So would like help on choosing drive train for the conditions. Sorry for the long post but I’m relieved the starting issue seems to be solved. Thanks….Mr Marty 51 nice scooter pics we have a lot in common panran51.
I was always on the side of the greasable ones, but recently I have heard others say the sealed one are better to go with. as for the selection, just measure your joints to determine which one is correct. always go with USA made and don't cheap out on them for reliability. last time I replaced one, there was a choice between two different ones. I ended up getting both from the local Napa so I didn't need to make another trip if I had the wrong one.
Installed one that was correct, then later took back the other one for a credit.
When the sealed ones stay sealed- the grease doesn’t “wear out” and there is no way for it to leak.
The only time anyone should even consider a greaseable ujoint on anything is if you drive a lot of miles then while hot you submerge it in a river/ stream crossing where it will be submerged in the water for more than a minute or two.
And even then- the offroad community is split on which is better. The majority I been reading & talking to- 70% says sealed is better even doing that.
Basically- old technology designed & built seals couldn’t keep out dirt & water. And grease from the 1930’s would break down. But now with great seals and advanced lube that doesn’t break down-
No need to flush anything out of the ujoint.
Look over the whole driveshaft for dings or dents or missing counterweights.
Best is take it to a driveline shop and have them balance it with new sealed ujoints. Once installed you should never have to touch it again.
On the transmission- consider a new seal where the yoke slides in if slip joint.
On the crankshaft/ harmonic balancer - do a new front main seal while balancer is off.
Also when pulling the shaft, before pulling it out of the trans. grab it and check up/down and side to side play. if it wiggles too much, there is a bronze bushing that will need love and attention.
I'm reusing my front seal, if it appears to not be leaking.
Used to be, I would've changed it regardless.
I've had too any bad new parts
In my opinion. Anymore, a working used part is just as likely to last as long or longer than any new part that replaces it.
I always try to buy the best quality part available.
Mostly the lifetime guaranteed parts don't impress. I'd rather not do any job twice or more.
I have trouble doing anything, even once.
Imon 3 weeks trying to get the oil changed in the mower
Thanks for all the knowledge sealed it is then. I always get the best knowledge from you guys. I did replace the front crankshaft seat, but wasn’t aware of the tranny and the bushing. Is the tranny seal replacement the same as front crankshaft seal?
The tranny seal will be a different seal, the bushing doesn't need to be replaced if the yolk is not sloppy. there is a tolerance that it can move but idk what that tolerance is.
