Another 2 door Tahoe for me
I keep forgetting to update this thread….
This fall I noticed the 1/4” return line from the IP and injectors was cracking. That hose was some diesel-rated hose that I bought from McMaster-Carr that was a good price, but obviously wasn’t great quality.
So I got to drop the tank and replace the hose with some Gates Barricade hose with an SAE 30R14 rating. This stuff should hold up well. This is what I get for trying to save a few bucks.
I thought I had replaced the hoses on the Tahoe at some point in time. Must have confused it with something else again. Seems there was a couple things I thought I'd done to it that must have been one of the Suburbans or trucks
Last winter I did a 100% new fuel system in it..........so you may have changed the hoses, but I ripped everything out that was in there to start fresh.
Maybe you got yours out of a batch that had been sitting on a warehouse shelf since before the pandemic? But still, installed in a location where it wasn't exposed to the weather, extreme heat or sunlight, it sure does look like it was exposed to UV/ozone or something that caused it to harden and crack.
The power steering/hydroboost hoses have started leaking, so I replaced those today. The front has some looseness, too, so I decided to take a look at that…. I found that the rag joint was adding a lot of slop, so I replaced it with the 137,000 mile one out of the red truck - a good improvement over this 319,000 mile one. The steering gear also has some slop, but I wasn’t prepared to deal with that today, so I left it alone for now. It definitely drives better now. Interestingly, it also steers easier now, so either replacing the fluid with newer fluid, or maybe the old hoses had collapsed internally, either way, it’s better now.
Tahoe needed tires, so tires it got. I went up to 285/75/16. Even though they’re 3” taller than the 265/70/16s I took offf, they don’t rub at all.
Next up I need to rebuild the front suspension. I’m going to decide in the meantime if I should do a small 1” or so lift or not.
D’oh!! I totally forgot what I did to get to this point!!
I didn’t want to just slap the tires on the stained and corroding wheels, so some dressing up was in order.
First, I sandblasted the wheels. After that I cleaned them with KBS Klean.
Then I sprayed a coat of epoxy primer on them. Unfortunately I struggled with gun settings that worked with the complex wheel shape and ended up with some minor runs in between a couple spokes.
And then I sprayed 2 coats of Eastwood 2K silver spray paint.
And then I finally mounted and balanced the tires.
Looks awesome!
I'm hoping to make some improvements to it this year that improve the looks of it. I need to paint the bottom of that door so it matches. I might also do some rust repair to the rockers and quarters - but my worry there is that if I start down that path..........well, we've seen what happens when I do that. Maybe this would be the one I actually do quickly and not start a full restoration.
It could happen.
You know better than that, after you do a full restore on it, here's what it will look like, just different year models.
I went to the junkyard for some treasure hunting today and that enabled me to get a picture of it in the open and in the light. I’m still tempted to lift it a little, but I think I’ll just leave good enough alone and leave it stock height for now and just refresh the front end with stock replacement parts.
A guy pulled up in his Yukon XL Denali and asked if I wanted to sell the Tahoe, so I guess he thought it looks pretty good 😎
View attachment 97040View attachment 97041View attachment 97042
Looks awesome Nate.
I agree, a small lift is what I would do. I cant leave anything alone either.
When I had my GMT400s I always wanted a GMT800, mostly because of the hype. Now that I have an 800 I do really like it, and it is a great platform, but I grew up in 400s and always have a soft spot for them. From my experience the 400s handle the rust/rot better being up here in the NE than the 800s.
Looks awesome Nate.
Thank you.
Driving it around Saturday renewed my love for it and the 2 door Tahoes. It's a really nice size to drive around and to park. I think if I spend a little time to fix the rust it has, I can keep it in good shape for many years to come if I am smart with coatings and keep it washed. But I also don't want it to be too nice that I'm afraid to use it. I think I've talked myself out of a lift for now, but I could see myself doing a straight axle swap in the future maybe.
Got some parts at the junkyard today to add to the pile of stuff to go ok this Tahoe. I went there for the 6 lug 14 bolt and a battery tray. The visor was a bonus….not sure if I’ll use it, but couldn’t pass it up, especially since they only charged me $35! And then grabbed the 88-94 cupholders while I was at it since they’re getting hard to find.
