Aluma seal or bars leaks ? ? ? ?
MrMarty51
Miles City, Montana
Yessterday, running chores.
Man at tire Rama tells me he seen a drip from under my truck.
I’m watching out for this in my travels. Drips out the left side like coming from the radiator drain cock.
Put truck in garage, relieve pressure, this morning small puddle under right side.
Install coolant system pressure tester, pump it to about 12PSI. No leeeks.
Remove top shroud, fan and bottom shroud.
Lower radiator hose dry.
Lower right corner of the aluminum Champion radiator.
I have used both products, aluma seal and bars leaks before.
Aluma seal i always buy in powder form. Mix about a half of one of those tubes with coolant, thoroughly stir and add to operating temp engine, install cap and run it.
Any opinions on which would be best on this aluminum radiator ?
It does have @Twisted Steel Performance thermal coating applied.
I cant afford to have this truck down any more than what its already been.
Thanks is advance for any opinions.
Either one is likely to cause damage in the form of plugging up things you don't want plugged up, long term. If you need the truck right away then I would replace the offending part rather than pour either chemical in. Then you can address any potential warranty issues with the leaking part in due time if it qualifies.
You can call them and they will warranty it... I would need the purchase date to start a warranty. Either way you would need to know the purchase date...
I can not find my receipt. 😢😭
Went through everything I have here and it is just not within my grasp.
I did find in my log book.
7/3/2021 installed new radiator from Twisted Steel Performance.
I’m still not sure on the purchase date though.🤷
Truck is back together.
No sealer has been added.
Topped the radiator and going to run with the cap loose until I gettit figgered out.
Got into the credit card statements and was able to pull up the purchase from 2021.
