5.7 diesel up and running
Thanks jay.I’ll definitely look into that and give it a go.Yesterday on eBay I came across a new elastomer insert drive governor cage which does away with the flex ring along with a o-ring/seal kit.I have a new old stock 3271 pencil injector pump that doesn’t have much use on it.It has no E tag on one of the governor screws like my current pump does so I want to take it apart and get rid of the flex ring altogether and set it aside for when I do need it.I also bought the updated idle spring kit that I’ve used on other pumps in the past.
Today I made a stab at replacing the old fuel tank sending unit in favor of a updated version with the water in fuel sensor.The old fuel line hoses are gone now.I got rid of all that along the chassis.Tomorrow I hope to install the new hoses and get the water in fuel wiring started.The old sending unit has a paint gun screen upon it that my father installed many years ago.
I think this will be a great feature when I finally have the water in fuel harness all in place.The new fuel lines are installed along the chassis up to the sending unit.The wiring connector is in position at the sending unit.I just need to run the harness along the chassis now and into the cab.I also have some brass fittings to go from 3/8 Barb to 1/8 npt which is what the lift pump uses upon the frame.Right now it has 5/16 Barb to 1/8 npt but I’m changing out those fittings tonight.
Today the new fuel hoses and water in fuel wiring was installed along the chassis.The 3/8 Barb-1/8 npt fittings were installed into the electric lift pump under the truck so all went okay with that.Just a matter now of getting the wiring in place inside the truck in regard to the water in fuel option and that’ll be completed.I used some Adele isolator clamps to keep the fuel lines secure to the chassis.
Last night I decided to purchase a set of used pencil injectors from a guy I chat with overseas.They look to be in pretty good shape.I’ll clean them up when they arrive.Total was around $250 delivered.
Can ya figure a way to test them? I never rebuilt that type, is that doable?
I have a new pop tester here I can try them on when the injectors arrive.I read the opening pressure on those pencil injectors is 1700psi and the later model poppet nozzle injectors is 1000-1225psi depending on the year.
I have heard they are a throw away type of injector.Once the needle and seat wear out they are done.There’s no real way to renew the internals if they are worn out completely.Some people say they are rebuildable and one guy told me they are not.You can take them apart,clean them up in a ultrasonic cleaner and reset the pressure but that’s about it.I have seen a couple YouTube videos on how to adjust them after taking them apart.
One video I found shows once you’ve adjusted them to the proper opening pressure you tighten down the center section until it bottoms out and while pressurizing them on the test stand you can find out if the tip drips fuel or if it’s just damp.They say if the tip is just damp your in good shape.It means the needle and seat are still perfect.
Here’s an updated video of how it runs now as of today.Much,much better at the moment.It runs smooth and then after awhile after reving it a few times and when it returns to idle it becomes rough again and not steady.Maybe an injection pump problem causing something to hang up or stick inside?I have another pump I can try on it just to see if it has the same problem.
Everything from the tank to the fuel filter housing and beyond is new.The injection pump is supposedly rebuilt with the E tag but still could be my issue.
Yesterday I noticed a small amount of coolant under the radiator on one side.Has all new hoses and clamps on it.New petcock with sealer on the threads as well.It must have a small pinhole in it someplace.This morning I ordered a new all aluminum radiator on Amazon with good reviews so I went ahead and got it.Total was around $350.Also wanted to show a picture of the lift pump under the truck with the 3/8 Barb fittings in place.
Same rules apply here as the 6.5… ensure clean bubble free fuel flowing through the ip. Measured pressure at the ip inlet… in metal T is critical. Little rubber flap in the hose to the ip is a more common thing than many realize. It’s been WAY too many years for me to remember pressure range on that pump.
I’m heading back to work in a couple days so I’ll get back at the truck when I return home.I’ll put a clear hose on the pump return fitting and see if any air is upsetting delivery.I have a fuel pressure gauge here with a barb fitting on each side so I can easily make it a permanent thing under the hood to monitor fuel pressure.I’ll also take the fitting out of the governor cover and ensure it’s clean with no debris.
Today I also purchased from eBay a low coolant alarm system with a probe,indicator light and associated wiring with warning chime.Theres an extra port in my current radiator and replacement radiator that’s on the way where I can install the probe.At least I can keep an eye on things while driving the truck should a leak occur.I think it’s a good feature to have in case coolant levels drop in the radiator.
Here are a couple pictures I found online showing a hole in a 5.7 diesel piston because of a bad pencil injector.I’ve never seen this happen on the olds diesel.Very interesting to see that’s for sure.Supposedly the owner was saying the engine ran pretty good all along until this happened.
It definitely pays to have your injectors checked and gone through if necessary by a pump/injector shop with a good reputation that knows what they are doing.Any of you guys hear of Dennis Erickson?He is supposed to be a good guy with these pumps and injectors.
