dieselolds
The shop called today saying the collar is ready.Heres a picture of what it looks like.There isn’t much to it but I’m going to use larger outside diameter flat washers so the collar/ring doesn’t decide to work loose and fall out.Its a tight fit though.I had the pulley off and the collar is pretty tight upon the balancer.
I also bench bled the master cylinder and it’s back on the truck.The pushrod under the dash is also connected now to the brake pedal.Tomorrow if I get a chance I hope to put the grille back in place and the optional hood latch cable and the various parts that came with it.Instead of opening the hood from the outside,a cable will be used inside the cab.
