Rings and bearings while I have the engine out?
Yup, a voice from an experienced front pump destroyer.
Many many years ago, thought I needed to pull the enjun against the transmixer with bolts, even found a couple of bolts that was long enough.
That didnt work out so well.
When the transmission man came by my house I pointed out that the TC would not fit alla the way back, his reply, how hard did You force it ? Told Him it was a tough pull.
I pulled the TC from the trans, he instructed me to pull the front cover, yup he said, gonna take a new pump. He said the cover was still good.
He was an older gentleman and I always appreciated when He would stop over.
Even times when I wasnt doing transmissions, he once told me that I had the most interesting building in town.
I was always making something to make something else work. 😹😹😹
I took the engine out, took out the converter, reinstalled it (all 3 ledges), and measured 1.02+" clearance from bell housing mating surface to bolt holes face. Reinstalled the engine and still have 1/4" gap between bell housing and block. Noting's binding: I can easily spin the converter with one finger (the hub is started into the flex plate recess), and the gap is all the way around the mating surfaces. I can't remember if the trans rested back that much when I removed the trans-to-block bolts originally or not. Could the driveline have slid back that much when I pulled the engine, like the guys who installed my rebuilt trans had to pull it forward that much to bolt it all up?
Got it situated. Thanks.
What are these two brackets? This one attached to the front of the driver side engine mount. I don't know what attaches to it:
And I don't know where this one bolts up and what lines go into it:
I think those are the brackets that holds the transmission lines
I think transmission lines would be passenger side.
To me the first bracket looks like it's for the engine oil cooler lines.
On at least one of my vehicles, there was a bracket for the engine oil cooler lines at or near the front of the engine mount
I'm guessing the 2nd bracket goes about the same place on the other side for the transmission lines
Do You have the starter and heat shield installed ?
Top bracket almost looks like the one that bolts to the back of the bell housing then through the heat shield.
But if You have the heat shield bracket figured out then that top bracket will be as AK Dieseldriver claims it to be.
