MrMarty51
I didnt think the stuff in the pail looked dark enough to cause problems.The two stroke dye won’t cause any issues. I’ve run it many times. Red dye diesel also will not cause issues.
Right now I just can not make up my mind.
So far to pull this pump and install my original unit all there is is the turbo, fuel lines to the injectors, then fuel hose, IP gear bolts and the mounting nuts.
If I install the intake system, right now dont take too much and then if it still cuts out and makes lots of smoke like its doing then it all has to come apart again.
I used to take magnesium and whatever else is recommended for leg cramps and charlie horses. That caused the pain and frequency to triple up.
I stopped taking those supplements.
Now standing on these blocks of wood the cramping and charlie horsing is at an all time high. When I quit for the day, get in the house and in my spot, them darn things strike with a vengeance.
But enough of the whining, guess I’ll install that lower and upper manifolds and see how it runs.
Just curious, should I use the used gasket or install the new unit ?
Screw it, new one itiz. I’ll have another new one come Tuesday.
