dbrannon79
I'm getting there!
Got the refurbished batteries installed late evening. kinda goofed as I didn't pay attention to which side the positive posts were on. both of these were backwards. Luckily I was had enough cable length to get the connected using some top to side post adapters. I didn't feel like cutting off the copper ring terminals. drove the truck into town and filled the tank, noticed the PS fluid was low and there had been a wet spot on the concrete below the gear box, so while I was in town I picked up a bottle of steering stop leak. dumped that in hoping it will swell up the pitman seal some.
The fella at the battery store recommended me getting a battery trickle charger to keep them charged and explained to me that letting the truck sit weeks at a time is what most likely killed the batteries. the old ones wouldn't even take a charge anymore! I have one that only puts out 1.2 amps but IDK if that is enough for a dual battery setup. I might hard wire it into the truck at some point so I just have to plug it in like the block heater. maybe even tie it into the plug for the block heater and add a thermostat for the heater so it's only on when it gets cold.
I also need to order a cord for the 93's block heater hoping it's good. cord is missing.
