The engine did not get installed.
The torque convertor had not been removed from the transmission when/before the truck was pushed outside.
Truck back in, lifted the transmission, with a straight edge, measured distance from front of bell housing to the bolt lugs on the torque convertor, just about exactly 1”.
Removed the torque convertor, these things are HEAVY.
Popped the seal from the front pump, prepped the new seal to install, made a seal driver by using a hole saw through a short 2X4 block of wood then going to use a piece of pipe against the block and seal for a driver.
Poked the seal at the hole, seal is too small OD. WHAAAAAT ! ! ! !
Yup, called NAPA, the counter man checked the numbers, its for the rear output shaft.
He looks up the seal, sends us another, smaller yet.
Parts deliverer takes the old seal, returns with it. New seal will be here on Tuesday.
So I do more to prepare for the Air Dog lift pump.
Needing to get to the tank fittings to install a hose adapter to AN type and to cut the filler hose to install the regulator return hose, box gets unbolted and lifted high enough to get to the tank components.
After looking at the pipes and such from the tank sending unit, ordered in the metronome unit from Leroy Diesel.
This just does not seem to have an end to the spending.
And so the son that came to help, now that the engine install is on hold He worked on the tilt/lift/trim unit for his new, to him, boat.
After messing with that and determining its the electrical motor thats screwed, He is ?
A: looking on the www for a new hyddaulic motor/pump to replace the bad unit.
Or
B: screwing off on fakebook.
I should turn this into a voting poll, to be closed at 8:00pm on November the 5th.
If there is someone that knows how to set up a poll, go ahead, use this picture and get a poll set up.
The truck is now back out the door. Shop is shut down and I will mess with getting the Air Dog pump mounted to the frame while waiting for the sending unit thing to arrive from Leroy.
