dbrannon79
I'm getting there!
I found the hole. it's small and was plugged with crap LOL
Yup.
Already got snow there at higher elevations?Installed new Rotors and Pads as the old set had developed a bit of a grinding noise on the left. It started right after I had shown my daughter how to retract the caliper piston a bit to get the assy. off when she does her brakes at a later time. Anyway, new set needed breaking in so I went out early this morning, about 4 a.m. so I didn’t upset too many hot heads on their way to work. After several iterations of gradual braking to 5mph the caliper/pad drag was about gone. Much better than before when it was constant and got worse as I sped up. Decided to go for a longer drive south of town to give things more time to sort out. UT 68 is pretty deserted road this time of day. Stopped to get a picture of the Geneva Rock and Gravel quarry at Pelican Point. On the way south, I thought it might make a good shot so on the return home I made sure to stop and see what I could capture. Camera night shot capabilities never cease to amaze.
What are you using to lube the cylinders?This evening after work I had the wild hare to pull the 6.2 engine out and begin getting ready to see if it will run and what kind of condition it's in.
Got the home built A frame out and hoisted the engine up enough to pull the stand and attempt to attach a flexplate to the crank so I can attach a starter to the block to crank it. I quickly found out the bolts I had are too long and are for a clutch flywheel. ordered a set of ARP flexplate bolts from the jungle site that should arrive tomorrow.
I have more things to do before even attempting to crank it but I do know one if the things I need to find is a DB2 top cover with a working fuel shutoff solenoid or just the solenoid it's self. I had swapped the top covers from it on the 93 truck and ditched the inline one it had. I could plumb in that inline solenoid if I can't find one though.
if anyone has a working used one they want to part with let me know LOL.
I plan to pull the GP's and re-lube the cylinders, fill with some fresh oil. connect a gauge to the oil pressure port and prime the engine. then connect a fuel line to the IP, disconnect the injector lines and see if the IP will pump fuel. Then I'll almost be ready to fire it on the stand.
I had also used the turbo oil feed line from it on the 93, but just to test fire it I will plug that off and remove the turbo. probably also remove the upper intake so I can choke it in case I can't shut it off.
for me, this first test fire will be nerve racking LOL the engine will be on the engine stand and also hanging from the A frame for extra support.
I was thinking maybe some trans fluid or similar. the engine spins but has been sitting a while.What are you using to lube the cylinders?
Are you turning the engine over some before reinstalling the glow plugs?
Member 635 has fond memories of his OTR time on US-50 too.@Paveltolz
When I drove otr trucks I traveled hwy 50 many times across UT to NV, there is a sign that says " loneliest road in America" that's a understatement....
Those AARP bolts: are those old school high performance?Stainless oil cooler hoses from Leroy Diesel arrived today.
The AARP exhaust manifold bolts was in yesterdays mail.
Tomorrow or Friday I will use the HS auto shop glass bead machine and work some more on the exhaust manifold ports where they mate to the heads. See if I can get them down to shiny cast instead of the crusty/rusty looking stuff. I would not be concerned about it except there is little minute spaces between the rusty sections and I think it might leak out exhaust at those areas. I want them sealed tight shut.
They are stainless and black. Whatever that is. I will weld a small bolt to the head of these so they will have a stud pointing outwards, on only four of them, for mounting the GP heat shields, then I will take a pic of the works and postum in here.Those AARP bolts: are those old school high performance?
I honestly don't know what's going on with the injectors sorry.Well after work today I fiddled more with the 6.2 engine. the ARP bolts arrived for the flexplate, got that installed and the starter installed too.
squirted some penetrate oil into the cylinders after removing the GP's for now and took my ratchet on the HB bolt and rotated the engine over a few revolutions. it turned easily with the GP's out. no catches. threaded a gauge into the oil port where the sensor goes. Then I started looking at the other oil port where the line goes to the turbo feed. I had stolen the oil feed line for the 93 since this is what ultimately caused it to get parked by the PO. There was a steel line that connected to a port above the oil filter and ran over tot he valley where the hose connected and went to the turbo. since I don't have a hose for the turbo I am thinking about running a copper tube from above the oil filter over to the turbo and not removing the turbo just yet.
there is two other ports above the oil filter that are plugged off and one that's open which didn't have anything connected. I think that's just a threaded hole but not ported into the engine. I took some photos of the engine showing this area and of how close the injectors are to the manifold turbo side. the line nuts seem to be against the manifold along with one of the return lines flat against the manifold too. This I will need to tend to.
of the photos here, can someone tell me if the oil ports are correct as in the one with the adapter was to feed the turbo and the other two plugged one for oil cooler lines? also are these injectors the long body type or is something off with the exhaust manifold here?
...the hose failed so now there's a 1/4" NPT to -6AM fitting at the "T" vs. the feed hose threading straight in.
