I had 21X,XXX miles on my Delco alternator when it went out in the Burb. Don't know if it was from the factory, or a new replacement (there was no reman label on it) when it went out, but the Burb has the dual HVAC, premium sound system and power everything. The last set of Sam's Club lead-acid batteries lasted just shy of 8 years before one went bad in 2020.
Cs130 or cs144?
Either way sounds like acceptable life imo. Imagine previous owner changing it half way. Thats 105,000 mile average per alternator. I see nothing wrong with that for the cost of the alternator. Some manufacturers get 50% longer life, even double but the cost difference is ridiculous.
I own two Toyotas currently one of which is a pickup I got from a good friend. The parts last longer but the cost of each part is double or triple that of gm. Labor times are 1.5-2 times as much. So GM wins the long term cost battle.
And before going to the false assumption I also had of mpg savings -
2001 suburban 2500 hd 6.0 selectable 4wd BFG a/t tires 17.5mpg
2005 escalade 1500 6.0 full time 4wd street tires = 17 mpg
2001 toy tacoma pre runner 4door 2wd v6 street tires = 16.8 mpg
2007 toy fj cruiser selectable 4wd pathfider 2” lift slightly oversized a/t tires= 16.5 mpg
But on really long hiway trips both gm mog went up 1-2 mpg sustained freeway use
Both Toyotas slower than gm, weaker towing, rides not as nice obviously,
No increased mpg sustained hiway trips. Towing light trailers dropped mpg of the Toyotas but not GM.
The FJ is definitely best offroad. Not as good as the hummer obviously but an excellent choice. Hummer does 10.5 mpg driving full throttle everywhere. 12.5 when driven like a normal person drives.
Both Toyotas eat an alternator about 200-225,000 mile intervals from forum talk.
Cost is twice as much as a cs144.
Neither suburban nor escalade ever got an alternator up to when gone at over 200,000 mile.
Hummer with 6.5 is something like 150,000 miles is my guess right now and stock cs144 still. Definitely extra electrical load has been put on it.
I am planning on a new one going in with the new engine and making the old one a spare on the shelf. Last week before pulling engine I saw the volt meter bounce to 16v so the regulator might have just failed. But my hitch slide in electric winch got used a lot for rescuing so between that, the time the starter got skewered by rebar and was shorted out for about 15 minutes straight, the times I ran batteries low out camping then alternator charging them back up, same scenario running the air compressor at different events filling tires up after jeeps deflating then needing aired up, etc.- I worked the heck out of that alternator. Oh plus the two times the factory hummer start prestolite that weighs a million pounds hung up and once melted the side post connection off a battery- probably not good for the alternator too.
While typing my book saw AK DD’s post. So yeah- I think AC Delco Remy did a fine job with their design.
@ak diesel driver- cs130 or 144?
