jrsavoie
Recruit
You might want to add a sender before the filter also.Keyed up with lift pump humming, but before starting, the gauge reads about 5PSI. At idle it falls to what looks like 0 to me. Is that indicating a blockage at the fuel filter? I'm thinking I need to take the whole housing off and clean it out with how dirty my filter was.
Also, here's a photo of the line running from the test point to the IP. Should I replace it?
Thanks again.
He OEM lift pumps aren't known for supplying ample fuel.
Especially if you buy aftermarket, OEM style
