After charging the batteries for 4 hours last night they topped at 13.03 volts. After sitting all night they leveled out at 12.78 volts.
Here's what I did this morning. Went to controller...had 12.87 in. Had 10.47 out. Can hear the controller click in and out. After the key is off...controller is at 12.69 after finishing test. Also checked for codes- no codes. 15 minutes later checked batteries...now at 12.79.
I've seen the controller at 12 in and 12 out throughout all our conversations. Why does the output keep changing?
I'm still thinking glow plug controller is the problem not putting enough voltage out?
ak diesel driver said "So now would be the time to try extending the glow plug time to see if it helps your issue. The 60Gs take longer to get hot"
What do you guys think of this? Has anyone tried one?
Leroy Diesel has a Glow Plug Override for 6.5TD. http://tinyurl.com/mr2mrfwm
dbrannon79 - you said earlier you put in a time delay relay (where did you purchase it?) and why did you choose to over ride the relay instead of letting it work automatically? Wouldn't that harm the 60G glow plugs?
The engine has always started in 5 seconds which I've continued saying.
