Filter is fine. Just needs to be cleaned. New AFE unit costs $68 on their site. Amazon marketers have them a bit higher. Heath Diesel/Diesel Site no longer markets this Gen II set up, opting instead act as distributors (along with everyone else) for the SoB/S&B unit.
In other news, the LED lights are complete. Driving this morning they seemed a little cross-eyed as there wasn’t much side coverage. So, no warning for an animal or any hapless pedestrians stepping onto the road.
Looking down and checking the hood and lens alignment seems to confirm the need to move them outwards.
Grandson came upstairs asking ‘what time do we start Ops?’ My little trooper. '
We did the remove, adjust, check, adjust and re-attach dance. Wonderfull design concept making the adjusters inaccessible once the unit was installed and grille back on.
Then, when it came time to put the grille on…No Joy. The design for housings is such that they are about a 1/4 inch too far to the inside and the headlight openings in the grille wouldn’t clear them.
Well, not w/o cutting the grille opening anyway. I wanted to use my nicer billet inserts grill but not experimenting on that one so, went back to the older temp unit I pulled from the strip yard so I could go full on Dr. Frank-en-steen / Frankenstein
That seemed too have worked but, there has to be a better solution and I hope another company takes the chance.
