Thanks Will. I am with Stoney on it as well. my understanding since joining this forum and since owning this truck has been the same, ULSD doesn't have enough lube to keep our DB2's and DS4's alive and get their full expected life out of them without adding some type of lube. Stanadyne, power Service (not the 911 flavor but the everyday one) or 2 cycle oil and ATF. my rig has 295k on it and there is a date code sticker on my IP where it had been installed about half way through it's 28-29 year life, so just guessing the IP on it mow has about 150k give or take on it.
Will, I understand now what your saying about the fuel lites with Schaeffers and the 911 stuff. I will use up the power service I just poured into my tank and them switch over to Stanadyne (if I can find it locally) or just run 2 cycle / ATF in it at a 200 to 1 ratio.
Back to the issue at hand, I drove to work this morning all without any physical issues on the truck. starts up quick and easy, no miss, studering, no fish bite, nothing. I haven't noticed any power loss ether. only thing is that every time I step on the pedal and accelerate past 1400-1500 while driving, my check engine light turns on. as soon as I let off or get to a light cruising speed where I'm barley pressing the pedal the light turns off.
when I checked codes last night I am getting two codes. 35 - Inj. pulse width too short error and 36 - inj. pulse width too long error.
I will check all the connections on the IP and the PMD tonight clean them with a blow gun and re-apply some di-electric grease. then go from there.
I have a spare PMD ready to use behind my back seat all mounted on a headsink with an extension cable I can also try, but I will verify the engine harness first.
if all else fails to cure it, I can assume my IP is beginning it's decline to it's death. if this is the case, how much longer will it run... probably not much I would guess. if this turns out to be the case, this truck will get parked for a while as I can't afford to spend 1k on another IP right now.
