SnowDrift
Ultra Conservative. ULTRA!
Could you rephrase that?Where does ok be procure a pile driver.
I've looked into fence post drivers before
Where can I get one of those things in the video?Could you rephrase that?
How does "Where does one procure"Could you rephrase that?
An old timer over here. He has a Bantam drag line He uses for driving surface water wells. About 25 foot deep.Getting started on a green house
Yes it was.The one in the video was totally homemade
My wife bought me a 26hp Kubota, loader, belly mower, forks. So we would have something I didn't have to work on. Over $30,000.I think so: Kubota, Iseki,Yanmar Shibaura 15-25 hp = 5-12k$ + hinged hydraulic turner and auger for another 2-3k$. Usually a mini tractor complete with a tiller.
For example:
Do you run water while pounding, like I've seen done around here?Yes it was.
I have gin poles for the 59 W100 Power Wagon.
I had thought about a horizontal crank engine and one of them rope sheaves that when the rope has tension it pulls the load. Building a hammer with such a configuration and mounting it on the back of the flat bed. Run it through the gin poles then I could pound wells. See if Clarence would sell Me his hammers and be all set.
Would have to drive the sand point in two sections and weld the second half to the first half when its far enough in the ground to clear the top half of the gin poles. Could even make an even taller set of poles too.
Use the 6,000 pound bed mounted winch to stand the pipe on end into a post hole then set up the driver.
I have only watched Clarence pound with His Bantam. I have not pounded any. Clarence never run water while pounding.Do you run water while pounding, like I've seen done around here?
Average well by a friend was about 225'. He just posted this morning they were something like 340' and no water yet
His last post was 420' and still goingOh wow. That's deep.
Friend Just posted 520'. Sounds like a dead hole.Oh wow. That's deep.
That must be getting mighty close to hell.Friend Just posted 520'. Sounds like a dead hole.
That's the deepest I've heard around here.
A lot of this area was Grand Marsh at one time
