In a nutshell, yes, these motors are so badly balanced from the factory it's hard to believe.  I have a pristine 93 dually, I don't want a new truck, so I have put a bit into it to update things, and built the motor I wanted, and it took me 4 yrs now and it's not quite done.  If you plan to keep your truck build a motor right the first time even if it cost and takes a while to save the money, or cheap out now and plan to do it again down the road. These motors can be made to have lots of power and survive doing it for years.
		 . Ever since coming to this group I’ve learned a lot about these motors. Love this forum
. Ever since coming to this group I’ve learned a lot about these motors. Love this forum .I’m an old ASE retired wrench monkey. Will, first things first. Your hummer isn’t that ugly. Back to my issue. I don’t even know why Im going to pull the heads off. I drove it several times with the temp gauge going up to the danger level then coming down. Thinking it was air in the lines after flush for a suspected plugged heater core. Then the white smoke came then I knew
.I’m an old ASE retired wrench monkey. Will, first things first. Your hummer isn’t that ugly. Back to my issue. I don’t even know why Im going to pull the heads off. I drove it several times with the temp gauge going up to the danger level then coming down. Thinking it was air in the lines after flush for a suspected plugged heater core. Then the white smoke came then I knew . Chris, my block is probably a 95. 166000 miles on it. It’s probably not the best block to rebuild
. Chris, my block is probably a 95. 166000 miles on it. It’s probably not the best block to rebuild  , one guy here said the p400 blocks aren’t available does that also go for the heads.Sounds like (after digesting everything I read on this forum) the best thing to do is get an Optimizer short block if available if not a long block and have the internals improved ( like Will and Chris suggested) and a new set up IP. and a fluid damper and cooling system upgrades. Or just get a long block from Leroy,s and take a chance. Or after a compression check and yanking the heads off w/ no signs of damage just slap some gaskets on and take a chance. Depends how much I struggle. I am on Medicare you know
, one guy here said the p400 blocks aren’t available does that also go for the heads.Sounds like (after digesting everything I read on this forum) the best thing to do is get an Optimizer short block if available if not a long block and have the internals improved ( like Will and Chris suggested) and a new set up IP. and a fluid damper and cooling system upgrades. Or just get a long block from Leroy,s and take a chance. Or after a compression check and yanking the heads off w/ no signs of damage just slap some gaskets on and take a chance. Depends how much I struggle. I am on Medicare you know .I know it depends on how much do I spend? My old boss gave me the truck for free after it sat for 2 yrs because he couldn’t fix it. Did spend some getting it painted, still needs rockers. Thanks again gentlemen your a great bunch of guys.
		 I’m not alone thanks so much. I feel better attacking this with all your guys help. OK enough of the sissy stuff
 I’m not alone thanks so much. I feel better attacking this with all your guys help. OK enough of the sissy stuff . Boy a lot of good info coming from u guys. My biggest fear is after doing a compression test (cold) and finding the readings pretty even and not finding any signs of damage to the block, cylinder and top of pistons and putting it back together ( maybe a fluid balancer to help with the balance oh wait I’m throwing money before time
. Boy a lot of good info coming from u guys. My biggest fear is after doing a compression test (cold) and finding the readings pretty even and not finding any signs of damage to the block, cylinder and top of pistons and putting it back together ( maybe a fluid balancer to help with the balance oh wait I’m throwing money before time , and the Optimizer still having flaws. Maybe I just answered my own question. Maybe Ill just call Chris and see about improving on the Optimizer? Maybe if I can find a short block. Whoa I’m getting way head of my self. It’s been sitting outside for about two weeks,I definitely will drain coolant. Pull heater freeze plug. Maybe turn it over and get the coolant out of the cylinders. Because like dbrannon79 said, it will be sitting awhile while working  on a backup  car to get it to pass inspection. I definitely will report back with pic,s and findings, it’s just going to be awhile. I’m sure you guys still be here Thanks again  for letting me ramble guys.
