@THEFERMANATOR that is my biggest concern is that something else caused the tranny to fail. I run nothing but dex/merc fluid. Valvoline. I've had a bad intermittent dragging issue with the truck for a long time. Happens on and off all the time.. it actually feels like I'm overpowering the brakes even though I'm not. And when I take foot of throttle it's like a engine brake kicking on. Sitting at red light, sometimes when I take foot off brake the truck takes off without even touching the throttle like it should. Other times I'll take foot off brake and truck doesn't move till I apply throttle.
I don't know if you have followed my saga with it but this problem started after I let a guy do a brake job on the truck. And change tranny fluid and filter. I remember him unplugging a electric plug on the tranny then plugging it back in. Don't remember which plug it was. The problem started as soon as I left . It felt like the brakes were dragging holding the truck back . Kinda the same feeling you have pulling a heavy trailer. I have never smelled the brakes burning at all. And the entire brake system has been rebuilt a couple times trying to figure out the problem. Including the guys on here helping me rebuild it again with all Delco parts.
This truck has always been a power house since I got it.(up until that guy worked on it)... It took off like a Camaro , accelerated quick as heck, and ran like a champ , I could hook any weight to it and it would pull it no problem. And the guys on here had helped me make it even better.
I honestly don't know if prior owner did any modifications that are not visible, to justify how awesome it performed. But after that idiot worked on it that all went to pot. It's never been right since.. I don't think the brakes are causing it because theve been redone multiple times. To no avail, I don't think he screwed anything up changing fluid and filter because that was redone multiple times after by pro mechanic to no avail, (he was also looking to see if he could find anything the other guy may have messed up)..the tranny blew back in October so I put another one in... still have same problem.. so I don't think it is a internal tranny problem ..
only thing my brain comes back to is the plug he pulled. I know he fought with it a little but when I unplugged everything changing the tranny the all unplugged easy and plugged into new tranny easily.. maybe one of the wires pulled loose or something in the plugg when he did it..I'm seriously confused by all of it. Maybe unplugging it erased something in memory of the computer or maybe it's had a tune and unplugging it did something to programming.. ? I have no idea about that kinda stuff ( the computer stuff)..
Any ideas?
As for the core.. I was told it would cost a fortune to rebuild it. I don't know how it's done or if it's something I could do... There was alot of shrapnel in tranny pan so hard parts busted somewhere in there..
If you have advice bid appreciate it
