Jl2019
99ccsb-6.5
So we’re almost done with winter here in the mitten, and over the course of a few months, my injectors have slowly deteriorated. I could just order a new set, but if I did that I’d want marine injectors which is in my future plans anyway. But in an effort to save some money, I asked around and found a couple local diesel shops that will rebuild the ones I have for a lot less than the cost of a set of marines. I could just ask them to set the pop-pressure to factory specs, but since I’ve done a few modifications to gain some power and mpgs, I thought I’d try to come up with a number that would better suit my truck and possibly up my power/efficiency a little more.
here’s my list of air/fuel upgrades
-Wicked Wheel in a factory GM-8
-turbomaster set at 15 psi
-Air Dog DF-100 100GPH lift pump
-FTB mod
-3/8” IP inlet
-1/2” fuel lines from tank to valley
-Beans Diesel Sump
-Performance tune from Quadstar
There’s not a ton of info on pop pressure other than the recommended psi. That being around 2100-2200 psi. However I did manage to find an old thread on a different page of guys testing different pressures in the name of science. One of these mad scientists said he went up to 2800 psi and didn’t have any real issues. I definitely don’t want to push my luck so I was wondering if 2300-2400psi would be an option that would benefit my truck.
Any extra information on pop-pressure such as long-term effects of running a higher-than-oem spec psi, or improvements in fuel economy would definitely help.
-FTB mod
-3/8” IP inlet
-Beans Diesel Sump
