You need to spend a lot more time reading some older threads to keep that hummer engine alive bud! Or it is going to cost you many thousands more $$ long term.
The restrictor fitting: where the 1” hose connects from the thermostat crossover to the water pump. LeroyDiesel.com sells one that is nicely made and if you don’t mind spending the money- just buy it from him. But many of us here are trying to save money with parts, so just made them ourselves. I am guessing the $75 plus shipping to you will be double. So that why I figured maybe you make your own.
leroydiesel.com
When the design change happened they made a different fitting originally that still used same size hose, but had an opening of 3/8” diameter for 1/2” long inside the fitting. This restricted the amount of completely hot water going from before the thermostats back into the waterpump and into the block where it mixed with the coldest water in the system. Only having one return hose into the water pump. Is part of the fix in getting the same amount water to flow through the two sides of the block and heads. Hence the term “balanced flow”. But the change to the dual thermostat crossover meant too much maxed out temperature water not getting cooled off, so a company was hired to make the fitting for AC Delco who makes the water pump for GM. They out a patent on it, owner died, family wouldn’t release production rights to Delco or GM. So they went back to the normal sized one and problems started coming back. GM released what the details were to those of us working in the dealerships and said that IF an owner was to make this on their own that we are to never remove it, and to reuse it if we install a new pump. Then they said the estimated time truck owners would have spent making them. Then magically if a truck owner did not have one in his truck, we could add on that same amount of time to our warranty card for an un listed reason- so you figure out what gm was saying to do. Out here in the southwest where the overheating problem was the worst- they actually had a trainer show guys how to weld one up with a brass plug inside to remove then warming it with a torch in the middle of cool time so it would keep it from hardening then drill it out, or welding in an alternator spacer that had a gm part number from the older trucks, or making that from washers. They kind if tried to make it get to the public to do this on their own.
There was talks about using reducing bushings to 3/8” on both ends, but heat hose is not made in that size so that idea got abandoned. Gm tried at one point an insert that went into the heater hose and was held in place with a hose clamp- but that hose is already a tight spot.
Not everyone believes balance flow is an issue. However they all do a bunch of cooling modifications to try solving it not realizing this is the biggest issue.
Because of the crazy angle and reduced airflow our hummers have, amplified if you drive over 60mph because of the aerodynamics of our hood and windshield- this is a bigger problem. Where you are at, I doubt that becomes an issue. But if you do find your temperature creeping up- DO NOT get rid of your original radiator. DO NOT get the aluminum ones- there is plenty of hummer owners that all saw higher temps with the Davis, Griffin, and ebay radiators. Have it rebuilt into a 4 core preferably using dimpled cores. Those who have done the balanced flow and the radiator rebuilt that way never get over 210° no matter what they do.
Eric said has something like 50,000 miles on his custom radiator in his hmmwv and doesn’t have the restriction fitting and has only hit those temps a couple times.
