MrMarty51
HAHAHAHA, @THEFERMANATOR
You answered about the grounding issue and got it posted just ahead of mine.
yes I only tested it at the plug itself. I haven't located the ground yetOkay, when You test for voltage at the FDA, did You use the ground within the plug for testing purposes ?
Sometimes there can be a bad ground through the olug, or maybe a broke grounding wire.
But too, I am not sure that the actuator does ground through the plug. You will have to check that out to find out if it does.
Thats looking mighty fine.
You need the tech2 to read 246 codes.@THEFERMANATOR Is there a trouble shooting sequence for the 246 with auto option ? Picked up a 2000 , 1500 gasser. service 4wd light flashing, was not in fwd but after putting it in 4 low it went to 4 hi and will m not go into 2wd . I read somewhere about pulling the negative cable and it will go back to 2wd (unverified) as of now. no codes on obd link. Having trouble with tech2 it will not communicate with truck or any of my newer stuff either.
Afraid you would say that lol ThanksYou need the tech2 to read 246 codes.
