Rockabillyrat
SlIgHtLy StUpId.
I know Verlin, he's a good pump builder. What did he find wrong with the pump? And did you ever try to run it with 25psi inlet pressure like it was originally calibrated for?
Most pump builders don't run it on an engine after its been on a test bench unless you specialize in a particular engine. Other wise you would have to keep one of every engine in stock and ready to run at the turn of a key. That would be expensive as all hell.
