I told you a few posts up how it's still shifting. It's in limp mode.
Speed input is but 1 part of the shifting equation. Basic trans controls like those found on 6.5's use output shaft rpm's, engine rpm's, and throttle input for warm engine shifts. There are multipliers and limiters that figure in, but engine speed, road speed, and throttle input are the 3 primary factors. If you take 1 away it can still shift in limp mode which will run max line pressure and less than optimal shift points. Running for extended periods of time in limp mode is a great way to tear up hard parts inside your trans. It's your truck, do with it as you please, but don't be surprised when you split the reverse apply piston and trash your pump from running high line pressure. When a trans lets go from high line pressure, it is normally cheaper to drop 3-4 grand on a new trans than fix the old one.
