Dave, I mostly use a degree wheel and don't button the heads down till I'm sure things are the way I want them, I have seen stock cams that needed to be advanced or retarded with keys and very few are where they should be in stock form.. Your drop numbers are a bit more than mine, but you used a thicker gasket than I do.. so that gives more clearance's than what I see as well... your good and no chance of touching... once my numbers on the wheel match the specs I have next is plenty of putty on the piston and several turns on the crank, I use feeler gauges to match my gasket thickness and I check 4 holes not just one... over kill maybe but once I bolt the head & gasket down I don't worry... the marks on the gear drive aren't correct either, I never trust just the marks.. for instance the stock cam in my motor is advanced 4* wit a key, and per the specs it's only 1* advanced per spec sheet... I'm not going to use the stock cam but I wanted to check the gear drive, it's all coming back out when the new cam gets made...
