NVW
I had to change the heater core in my 95 truck, I had hoped I could take the core out without removing the entire heater box. I removed the screws on the bottom of the box but couldn't get the core to move. I then followed the manual instructions of removing the dash and the steering column. After I realized I would have to evacuate the air conditioning I had a second look at what was holding the core in place. There is a shitty little clip that holds the core in place, with it out the core can drop down and be removed.
The whole job could be done in an hour, the removal of all the other crap probably took 6 hrs not knowing what I was doing. I hope this helps any other poor bugger needing to replace a 400 series heater core.
