Big T
Not quite finished but running. Have a little drip at the quick connect heater hose and need to drain water and put coolant in it (rinsing it out on start up with just water). I just finished: New HO water pump, Duramax fan and new fan clutch, timing gears, Fluidamper harmonic balancer, Leroy's solid crank pulley, engergy suspension engine and transmission mounts. What a PITA to do drivers side engine mount with 4x4.
Did the Energy Suspension engine mounts make a difference? Is there a trick to getting them in?
