If you want to lower compression then Chris
@Twisted Steel Performance is the man to talk to. He offers several different ways to lower compression.
I've been ogling his website for this past month as I've considered what to do. Impressive....most impressive!
A thicker gasket won't get a point drop, I've cc'ed many and that is just hearsay ..
See...now this is why I decided to pipe up and ask for help! A body can read till they're blue in the face, and think they know what's what, but it's all bull pucky without a measurement!
My reasoning for wanting to drop the CR is, of course, because I want to chunk the Asthma Attack turbo after engine break-in. And why not plan ahead for full utilization of it's replacement? So I considered all the trick goodies for a rebuild...until I decided, even though the original block and heads showed no signs of cracks, you can't build for strength on top of a weak foundation. That, plus I found the remanufactured Optimizer for less than the cost of rebuilding the stock L65. The drawback was I had to take what was on offer, vanilla.
So, the immediate plan after taking delivery is to install studs top and bottom. I figured this would be an opportunity to go back with the thicker gasket? But apparently the focus should be going back with a QUALITY gasket...which would be which? Fram? Mahle? Cometic?
Is the jury still out on installing a main girdle? Read some that it was the ticket for bottom end strength, short of the P400...and read some that it was yet to be proven useful. Thoughts?
Port you heads for better flow, because its cheap, not hard to do, helps everything in the engine: more power, more mpg, lower egt, probably saves baby whales too.
But when you do it, unshrouding the valves will trim some of the CR also.
Well, if the heads are coming off anyway, maybe I should. But what am I looking at cost-wise, ballpark? I'm having all this done, by the way, in case I wasn't clear on that. Not because my pockets are deep, or because I haven't the desire or ability to do it myself. Fact is I don't have the facilities at hand with my current living situation, and my health is such that I can no longer tackle these big projects. What I DO have is a broke down dually..AND a need for something more useful than a broke down dually!
The pistons are what is different iirc. On going from the 21.5:1 to 20.5:1....
Well okay then, that answers that question! Thank you!
The ten thou thicker gaskets drops something like .1
Or .15 I thought? It is negligible....
Not even close to the full point I had been led to believe. So much for tthatbright idea!
out of curiosity, where did you purchase your reman motor?
I left that out, not wanting to seem as if I were promoting a particular company. But I used US Engine Production...headquarters in NY, factory in WI. Hope I didn't mess up! Checked the webs and couldn't find anything negative...except one pissed-off individual that posted on RipOff Report. But if anybody has any input, positive or negative, let me know now.
Buying a reman engine would scare me. Hope its not the place on the east coast.
New York is East Coast according to Thug Life! But then, so is North Carolina...according to the maps, not the thugs. Which place is the bad place? Do tell!
