I´m at what I thought was the end to my big project of converting my 6.5 suburban into running on wvo.
I have re-done all the fuel lines (except the diesel return line, I ran out of hose, haha
), and made an almost identical setup for the diesel and the wvo like the following:
Diesel side:
tank->inline plastic prefilter->T out to diesel heater->acdelco ep1000lift pump->coolant heated 10micron filter->selection valve
WVO side:
tank->inline plastic prefilter->acdelco ep1000 lift pump->coolant heated 10micron filter->plate heat exchanger->selection valve
Common, after the selection valve, the lines run like this:
selection valve->electrical heater (for wvo)->T for temp gauge->T for fuel pressure gauge->original fuel filter manager.
From there onwards it´s stock until I´ve connected onto where the rubber hose from the ip/injector return to the diesel hard line was, where I´ve connected a rubber hose to/from the return fuel selection valve. I have a clear plastic pre filter here as well to monitor the return fuel.
I also have fuel pressure gauges between the lift pumps and the filter in both lines.
The truck runs well, and I can read pressure between 4-7psi on normal driving, lowest I´ve seen is 1,5 at WOT, and the highest is 8ish with lift pump running and engine off. However, it dies after a while (like 5mins of calm driving) when I am running it on WVO, and I can see that it sucks air somewhere even on the diesel side.
I can see some very small air bubbles being sucked into the pre filter on the dieselside - almost invisible. On the filter on the return side, however, a rather large air bubble comes into the plastic inline filter every 5-10s.
I´ve been trough all the connections I´ve made and re-tightened them, without any luck, so I fear that it might be sucking air either from the fuel filter manager, or from the line from the FFM to the IP.
I´ve bought clear tubing for testing purposes, and I am taking the sub to a shop on Monday to try to hunt down the air leak(s) again in temperatures above freezing, but all this doing my regular job and not being able to play with my car has led me to thinking (a bit to much), so I have some questions I´d like to ask:
1. The plastic inline filters do not fill up with fuel. On the feed side, it´s a small air bubble, and on the return line a much bigger one. When I´ve been driving the truck, and I stop and idle for a while, it fills a bit, but still with a large air bubble. Google has told me that air bubbles in inline filters are completely normal and not dangerous. Any opinions here?
2. The diesel return line is the original line, so it can definitively have some leaks I haven´t seen. I´ve been reading up about it, and some people say it will affect the fuel system, some claim it doesn't´t matter. Opinions?
3. If my next quest for the air leak(s) doesn't give results, the only thing I haven´t exchanged or improved is the FFM and the line to the IP. I´d have to order the seals for the FFM from the US, so I´m considering ordering a kit for the FTB mod to do it while I have the FFM out anyway. It would make it even easier to T in a fuel pressure gauge AFTER the FFM which I am quite keen on having. However - my budget for this project is well spent, and I can´t really see myself buying new lift pumps again as well. Would the FTB mod work with the EP1000 lift pump, or is that asking for even more trouble?
Thanks for all answers and guidance. This newbie is learning every day on this forum!
Cheers,
Svein
Diesel side:
WVO side:
Cheers,
Svein
