I would like to expand on "Wrap". Wrap is just that and alone can fail easily and fall off. The better way to do it is "wrap" and then paint the wrap so it becomes hard. The painted hard wrap can't come loose and unwind on it's own. The amount of air coming off the engine cooling fan is just one thing to work the wrap loose. This way minor/major damage from swapping injectors etc doesn't cause it to all fall off. The crossover is very hard to keep on with all the critters like Leprechauns hitting it at 65 MPH. I don't bother with the crossover pipe anymore. In conjunction with the paint I push the wrap ends under itself and avoid using 10,000 stainless ties on the manifolds. The paint locks the wrap in place. Wrap the manifolds and the downpipe. A turbo blanket is a expensive single item, but, worth it.
Just saying the paint is the easy part of wrapping.
https://www.thermotec.com/products/exhaust-insulating
https://www.thermotec.com/products/coatings-adhesives/hi-heat-coating
To finish off a clean and well-protected Exhaust Insulating Wrap application it is recommended to use the Hi-Heat Coating. The coating will protect the wrap from abrasion and harmful liquid spills. Extra resins and binders toughen the surface, extend the life of wrap by protecting it from friction, and seals the pores to minimize the penetration of harmful liquids. Hi-Heat Coating can handle direct and continuous heat of 2000 degrees Fahrenheit when used with ThermoTec Exhaust Insulating Products. The coating also works excellent as a paint directly on metal surfaces and can handle continuous temperatures up to 1200 degrees Fahrenheit.
