@Ratkilr Let me save you some heartburn about B.S. 6.2 myths. Lets call this the myth busters post.
ECT over 210 is asking for it.
Confirmed. Rings loose their temper resulting in blowby - affects many IDI engines like the Ford 7.3 etc. You watch one guage and thats engine coolant temp. 6.2 and 6.5 like to crack to death especially heads getting hot.
EGT around the melting point of aluminum will s#it melted pistons out the exhaust.
Busted! Although a bad injector will melt a piston with low EGT... I have attempted to s#it pistons out the exhaust sustained 1550 EGT towing a grade for miles and only scorched the turbo blanket. This on a non-coated 6.2 piston bottom end. Note ECT was in control at and under 210. EGT tells you how hard its working, maybe to downshift, and where the turbo might melt - a really high number.
10 psi of boost is the limit of head gaskets.
Busted!
the TTY head bolts and lack of them get about a 200k life give or take. Reuse of single use TTY bolts doesn't help this reputation. Combined with high ECT many bolts just fail and let the HG's pop. Factory 6.5's run up to 14 psi. I ran this with TTY bolts. 17+ psi because boost sensor pegs at 17 when doing high EGT run, 24 psi on HX40II, and 15 on the ATT with ARP head studs.
I have found the edge on some things and have the carnage to prove it. Just saying : save some heartburn from old B S. Myths.
