Ok. So I’ve been trying to gather info on what to do about adding an appropriate amount of oil. While doing that I’ve also stumbled on some weird info regarding oil to use and the refrigerant charge! Let’s see if I can lay this all out.
Everywhere I look, it says the total oil charge is 8oz. Ok. But then I see that the system should take either PAG 46 OR PAG 150! What?? I used PAG 46 because that’s what my brother found when he looked it up at work. Well apparently there was a GM Bulletin that said they wanted you to use PAG 46 for all applications except R4 and A6 rather than the original PAG 150. Since I have the H6 compressor, I’m good to use PAG 46 instead of the original PAG 150. Whew. I found the same Bulletin issued by AC Delco in a nice format with additional info.
View attachment 53207 View attachment 53208
Ok so now on to how much oil. I found a lot of conflicting info on how much to put in for components. Unfortunately I don’t have a factory manual, so I decided to go to the library to look it up. They no longer have service manuals, instead they have a subscription to Alldata. Here’s the info they have.
This seems pretty reasonable to me, so I’m going to go with these numbers. I briefly mentioned it before, but this is actually the SECOND air conditioning leak I’ve dealt with this year. The first one was a slow leak at the compressor hose connection. For that leak I replaced the accumulator. I added 3 ounces of oil at that time because that’s the info my brother found when he looked it up. So not only am I short on oil this time, but I was also apparently short on oil last time as well. Here’s some math I did and based in that I am going to add 2.0 ounces of oil to correct both errors (this gives me a little extra for fudge factor).
And then the refrigerant amount. This is dumb. I charged the system with 3.0 pounds of refrigerant last time. That was based on the sticker on the accumulator I removed the first time which looks to be factory.
Well as I was looking up oil quantities I noticed refrigerant quantities that were a lot less than that!! Alldata says 2.0 pounds and 4 Seasons says 2.25 pounds???
View attachment 53204 View attachment 53209
I guess I’ll go for the lesser amount and see how the gauges read. I can always add more later. I’m refilling from 12oz cans, so 2.25 is easy for me to do, but I will try to shoot for 2.0 and see how the gauges read. This is all so dumb. It doesn’t seem like it should be so difficult to find the info I need to service this thing correctly.
Check this info out and see if you come to the same conclusions I did.
