A good suspect is one or both of the pressure relief valves under the oil filter..
Yeah. I always hope for an easy solution for problems too.I feel bad not being able to have a $20 fix for gruss the new guy. Like the news caster that on day 1 has to announce a natural disaster.
im wanting to try everything before resorting to pulling the cam.
maybe 500 miles. heads were cracked, wasnt aware, water got into the oil.
any way to insp cam brgs without pulling cam? if not, is it possible to pull cam w/o removing heads? remove push rods and lifters do it? change bearings with engine still installed?
looks like the cam is coming out.A good suspect is one or both of the pressure relief valves under the oil filter..
