Or I am out of things to drive...
So I have a "missing feeling" after startup on my 2003. Turns out to be a solid miss on #2.
Further the exhaust manifold is leaking again.
After testing so far the #2 injector is dribbling under pressure and another one has a high return rate. The HPCR injector set and install will cost more than I sold the 6.5 Banana truck for... Waiting on compression test results as a dribbling injector can burn a cylinder out.
Manifold has shrunk and is warped. So much for AFE. And their support isn't home asking if their stainless steel or tube SS manifold would take the heat better. So I got a BD 2 piece replacement.
