Stock radiators are more than adequite to cool these engines. I know somebody else who is running close to a 700 RWHP tune in his LLLY using a STOCK LB7 radiator, and even in ARIZONA heat he still manages to handle most grades without overheating. He does say it gets up to 230 or so in 115-125 degree temps pulling a 7% grade, but he can still hold highway speeds with it. The LBZ radiator is over 2 inches taller than the LB7 radiator, so I see no reason to add cooling. I know guys running these trucks for hot shot's, and they don't overheat with stock LBZ/LMM cooling systems grossing 30K+ provided the system is clean, working, and the fan clutch is good. As to the mishimoto, I wish you luck. Theres more than a few LBZ owners who have had the LBZ MISHIMOTO's fail in under 3 months. MISHIMOTO always blames the cab mounts, then radiator mounts, frame flex, and so on which I find HILARIOUS considering the radiator mounts to the intercooler, and the frame flexxing has NO impact on it.
