Yesterday I was at a store and saw a guy fighting with a liftgate on his truck. I walk up and asked if I could show him an easier trick I learned. He said a line we've all heard before "I've been doing this 20 years." To which my favorite response is usually "You've been doing it WRONG for 20 years mother f****r !!!" To him, since he was polite, I skipped the last 2 "non church words". Then I said let me show you- now his job will be easier time he uses it.
I have always held to the thought of keep the pressure high, and need less turbo. As I read your last point and think to myself, yes that works, but if you just kept the pressure up like I have for the last 20 years...Then I hear my son in the other room laughing as he repeats the words I said to his friend telling the story.
It takes hearing my own words at the right time sometimes to consider. Have I been doing it wrong for the last 20 years?
I am very reluctant to give up the power in compression. I know I don't want to for the hummer until I can fit a real turbo and compensate. Are there builds done still running a gm6 with higher boost numbers and maybe a wicked wheel that can compensate the loss?
I am going to print out the charts you posted and study them till more clicks in my head. I have great concearns about worn rings dropping compression on already lowered compression and hard starting. I get when everything is new it will fire easy. But once there is 150,000 milesor more on it...??
My mercedes diesel is the great 6 cylinder that has 22:1, the only one touted as a better long life is the 5 cylinder om617 which has 21.1:1. I know different designs on many things, but the same idi, piton top, injector style, precup style, crank to rod/piston weight ratio,bore to stroke ratio,... basically Detroit/GM copied all the key factors from the 1970's Mercedes Benz design table and made it a v8 for GM to work off of. Then GM made multiple key changes, all of which are the problems we all know of today. Idk, have the MB guys learned to drop there compression also? Some reading in my future.
I am trying to accept what you are saying, but hard to swallow this pill. A more open mind is going to read on and try to find old 6.5 info... please continue to share
