Other 6.5 TD USED PARTS FOR SALE
Got the turbo yesterday thank you. One ? tho, I see you have a homemade turbo master on there did you have the black hose hooked up to anything?
The controller is made by racedaymechanic. I had the hose attached to a pre CAC/IC boost gauge to measure pressure drop across the CAC/IC however it normally goes to the Dodge Ram HX40 pressure gate controller points down that does not fit well on the 6.5td a Dodge Ram HX40 super controller points up and is more forgiving.
SEE: http://ptwiringsolutions.com/t/turbo-kits-and-waste-gate-controller
Sent you the payment via PayPal for the alternator bracket! Can you send the bolts for the bracket as well. I forgot to ask if you have the wiring for the alternator on the drivers side?
UPDATE LIST OF PARTS FOR SALE.
6.5 TD & OTHER CHEVY/GMC PARTS “USED” FOR SALE (AS OF 24 DEC 2016)
Parts are off of a 1999 GMC K2500 Suburban 6.5td “F”. All prices are + S&H, PM your zip code so I determine shipping cost to your AO, PAY PAL accepted.
Two (2) “GREY” Remote FSD (aka: PMD) used in good working order on cooler plates & few extra resistors and a modified hemostat for R&R of resistors, I ran redundant FSD’s (package deal will not break up) $215.
16 Mechanical Injectors for 6.5 diesel (8) w/new 304 nozzles & (8) for spare parts ‘none of the injector bodies are cracked’ (package deal will not break up) $165.
3” to 4” Stainless Hearthrob turbo downpipe used $40.
Energy Suspension 3.111 6R GM for “Small Block Chevy” clam shell styled motor mounts for 4wd (1) new & (1) ‘slightly used’, I was misled on the fitment and I had installed one on the 6.5 and found out it was not the right one “these are not for the 6.5td or 454” $30.
Throttle pedal assembly w/good sensors ‘drive by wire’ $50.
Charge Air Cooler (aka: intercooler) mounts between front chassis rails complete from turbo compressor outlet & back to intake (bulky consider this for S&H) $200.
Fuel filter manager with water sensor, heater used with new larger sized fuel filter $40.
Hayden med-truck fan clutch (spin on type) “cooling upgrade” has 112% more engagement area than the severe duty 6.5 fan clutch excellent shape $40.
HO water pump good condition used only waterless EVANS coolant no EGW (spin on fan type) (steel fan available at extra cost) 1999+ 6.5 $50.
Dual thermostat coolant crossover assembly w/temp sensor & spare stats $40.
Intake manifold (non-EGR) upper & lower “upper is trimmed for bigger turbo install” can be used w/any of the usual GM turbo’s with extended hose $80.
Front accessory brackets (both sides) late model 6.5 has the rear bracket for dual alternator install (no front gen/alt bracket) (heavy so consider this for S&H) $125.
Belt tensioner good condition used $20.
DS4 injection pump 5521 ‘good to fair condition’ $200.
6.5 starter “REMI” used good condition $60.
There are some other separate listings in the for sale section
I have not stripped down the 6.5 yet and there may be good parts as well as the side-mount turbo exhaust manifolds (no x-over pipe).
Do you still have that intake ? I'm very interested
tell me more about the injectors.
Are all the bodies german bosch?
What brand are the new nozzles? how many miles on them?
I assume you bought a second set of injectors to rebuild, swapped them out, and kept the originals to rebuild in the future?
All Bosch bodies & 8 new aftermarket nozzles w/25 miles on them, the other set of the bodies include everything but nozzles. The mileage on the nozzles was test run into town and back a few days before the flood here.
I found a heavy branch among many in the flood surge which fast as hell had pushed the tubing from the CAC (lower chassis mounted) to the intake off so when I started the 6.5 to try and leave it sucked lots of water hydro locking the diesel.
1 set of bodies are originals I had rebuilt myself a few times the other set was from Heath w/311 Bosch marine nozzles.
I can include the injector socket for $25. extra or make me an offer if interested.
S&B air-box insulated w/1.4k heat barrier, top cover was modified for cowl type scoop however making a new cover would be easy, has full 4" runner from filter to compressor "perfect for HX40 install" however by using a reducer it can fit on 6.5td, has CDV hose $70. + S&H. DSCI0009.JPG
6.5 TD & OTHER CHEVY/GMC PARTS “USED” FOR SALE (AS OF 14 JAN 2017)
Parts are off of a well maintained 1999 GMC K2500 Suburban 6.5td “F”. All prices are + S&H unless otherwise noted, PM your zip code so I determine shipping cost to your AO, PAY PAL accepted.
Shipping to: US mainland, Hawaii, PR, Alaska and other US territories only.
Two (2) DS130D GEN/ALT’s 105 AMP for 6.5TD application w/proper sized pulleys for tach. $100.00 “shipping & handling included (ground) USA mainland only” other US area’s S&H extra.
Energy Suspension 3.111 6R GM for “Small Block Chevy” clam shell styled motor mounts for 2 or 4wd (1) new & (1) ‘slightly used’, I was misled on the fitment and I had installed one on the 6.5 and found out it was not the right one “these are not for the 6.5td or 454” $30.
AMSOIL Dual bypass oil filtration manifold, reusable steel AN hose ends and 6.5td oil-filter block adapter. $200.00
Fuel filter manager (FFM) with water sensor, heater used with new larger sized fuel filter (no FTB mod) $40.
Hayden #2784 cooling fan clutch new for tall deck 454 $40.
HO water pump good condition used only waterless EVANS coolant no EGW (spin on fan type) 1999+ 6.5 $50. (steel fan available at extra cost)
Intake manifold (non-EGR) upper & lower “upper is trimmed for bigger turbo install it has two adjustable Hobbs valves installed for triggering staged water injection or CAC cooling spray comes with the GM boost sensor & boost gauge sensor port ” can be used w/any of the usual GM turbo’s with extended hose $150.
Front accessory brackets (both sides) late model 6.5 has the rear bracket for dual alternator install (no front gen/alt bracket) (heavy so consider this for S&H) $75.
DS4 injection pump 5521 ‘core good to fair condition’ $100.
6.5td 12v starter “REMI” used good condition $60.
Five (5) CSB oil filters NAPA # 1061 all for $25.
NP246 Autotrac t-case (GMT400) push button dash switch ‘near new’ $10.
4l80/85E & manual trans to NP246 adapter “may fit other applications” $80.
There are some other separate listings for 6.2/6.5 tools, compression tester, differential, t-case etc. in the FOR SALE section
I have not stripped down the 6.5 yet and there may be good parts like pre-chamber cups, flex-plate, AN oil cooler adapter’s to AN block fittings as well as the side-mount turbo exhaust manifolds (no x-over pipe), misc. electrical controllers and other parts not needed w/my Cummins conversion.
