FellowTraveler
6.5 TD PARTS “USED” FOR SALE (MAINLAND USA ONLY)
All parts are off of a 1999 GMC K2500 Suburban “F”. All prices are + S&H, PM your zip code so I determine shipping cost to your AO, PAY PAL + fees accepted.
Gear Drive (DSG) DS-4 replaces timing chain & ‘never needs replacement’ $225.
Fluid Damper ‘never needs replacement’ replaces harmonic balancer $250.
Dual Alternator front bracket w/idler pulley comes with spare belts and stock length belt to take one gen/alt off line if the other fails $120.
Two (2) “GREY” Remote FSD aka: PMD on cooler plates w/extended harness & few extra resistors (package deal will not break up) $225.
16 Injectors (8) w/new 304 nozzles & (8) for spare parts ‘no injector bodies are cracked’ (package deal will not break up) $165.
6.5 TD HX40w 18cm2 conversion (package deal will not break up) CKO HX40w turbocharger 4” into compressor and 4”out 18 cm2 turbine housing, ‘race-day’ parts to include oil feed line w/adapter, SS braided drain line w/AN fittings and mechanical fuel pump block adapter, full sized HX40 3” downpipe adapter for the GM 6.5 TD and ‘race-day’ mechanical waste gate controller, included is a 4” full marmon turbine outlet for converting to 4” down pipe (package deal & will not break up) $485.
3” to 4” SS Hearthrob turbo downpipe $40.
Bosch reduction gear starter 3kw (new but mounted) $90.
Dual thermostat housing, high output water pump ‘spin on fan’, bypass flow restrictor med truck fan clutch and steel fan assembly (package deal will not breakup) $120.
Energy Suspension 6.5 TD or 454 motor mounts for 4wd ‘slightly used’ $30.
PSC high output hydro-boost P/S pump w/mall parking assist eliminator $80.
Two (2) DS-4 injection pumps ‘one works but needs rebuild the other as core’ $200.
Throttle assembly w/good sensor ‘drive by wire’ $50.
Heath programmed DTC OBD-2 for 1999 K2500 Suburban equipped w/4L80 $250
Charge Air Cooler (aka: intercooler) mounts between front chassis rails complete from turbo compressor outlet & back to intake $200.
