Flo Pro Exhaust
NVW
Castor, AB.
I recently purchased the 4" Flo Pro Exh. for my 98. It is quieter than the Hearthrob on my 95, which I like. It was harder to install, hanger on the tail pipe was cheap and in the wrong spot. The tail pipe took some tweaking, it wasn't bent quite right. It could have been bent a bit more to the frame rail. The spare had to be shifted to the drivers side. It came with hangers but I cut the old hangers off and reused them, they have the little knob on the end to keep them from coming out of the rubber isolators.
IMG_0894.JPG IMG_0895.JPG IMG_0896.JPG IMG_0897.JPG IMG_0899.JPG IMG_0900.JPG
Now that it is on I like it, install wasn't so friendly.
Before
After
It was much warmer which may make a difference on this run
Looking back, in all fairness. When I got the Hearttrob exh, it came with the same type of hangers. I didn't try to use them, I went right to reusing the original hangers. I wasn't as lazy then.
Oh, this exh was from Leroy Diesel, the best price I could find.
Nice install, I have the Hearthrob SS system which is welded at all connectors and now that it had held sea water or a few weeks I suspect it will need replacement sooner than later....unless the un-burnt diesel coating inside protected it.
  • Like
Reactions: NVW
I haven't had the chance to work with a FloPro yet. I had a lot of reports though that the install went smoothly. You must have gotten one built on Friday? ;)
Thanks Leo
Thanks Leo
The band clamps are nice but don't hold it together like one pipe inside the other. It wasn't hard, I just had more trouble than the other.
Thank you Leroy
