toddlnrd
My first diesel!
Please help, I am at my whit's end!!
This has been a 6-7 month ordeal. I am getting codes P0251 and P0370. The truck has no power (NONE whatsoever). It barely will come off idle.
I have performed the following to fix the problem.
1. checked all grounds, cleaned grounds and even replaced a ground.
2. replaced lift pump with Heath Lift Pump
3. replaced the Injector Pump with Heath rebuild
4. replaced the crank position sensor
5. replaced the ECM with Heath programmed ECM.
The truck has not changed its reaction to my right foot with any of these "fixes". I have spoken to Bill Heath extensively on the problem and spent too much money on it already.
This is my family daily driver and I am open to any suggestions to get it back on the road.
Thank you,
Todd
Thank you,
Todd
