FellowTraveler
Best I can find on that turbo is that # is used in FORD truck & BUS Cummin's applications, keep in mind BIG Holset/CKO's HX40's have 4" in compressor & 4" out turbine and choice of T3/T4 outlets while a raceday exhaust adapter will allow for bolt on the turbo will not reach it's full potential w/o a full marmon or other full 4" exhaust, here is a chart for HOLSET turbochargers used in Dodge Ram Cummin's applications which can be adapted easy to the GM 6.2/6.5 platform...Is the HX40W from a 95 cummings a good turbo? Or is there a particular part number, year etc for the HX40W that I should use for my Optimizer build? I do see different syles, I guess it's the waste gate and actuator.
I do have the specifics on the 95 turbo.
Kit #3802619rx
Assy. #3533010
Serial# 1295658
THANKS
http://www.myholsetturbo.com/images/holsetpartnumbers_2008.pdf
